Results 1 to 21 of 21
Like Tree2Likes
  • 1 Post By DroidXcon
  • 1 Post By RLLangley
    Default Am I able to use MultiWindow Complete Control V2?
    I'm pretty new to all this root/flashing/etc and am a bit confused with the whole lingo around it. Don't know if I meet the requirements or how to go about meeting them. They are listed as "Requirements: A supported base, deodexed, CWM recovery". I'm rooted using the Exynos Abuse and have only really installed Titanium Backup and Root Explorer. I want to be able to find a way to decide what I can use in the MultiWindow and found this option over at XDA which looked pretty good. Can anyone help me out on what I need to do to be able to use it?
    Here is the link to the xda post. Hope this is allowed.
    [18 DEC][i605][VRALJB] MultiWindow Complete Control V2 *App Update* - xda-developers
  2. #2
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Carrier
    Stock for now
    Default Re: Am I able to use MultiWindow Complete Control V2?
    No simply being rooted will not be enough. You need to be on s deodexed rom. I would explain this is in detail why. But I need to put my son down for a nap. What you need to do is flash the second rom called stock deodexed found here http://forums.androidcentral.com/sho....php?p=2407830
    [How to][VZW GNote2] Root/Rom via Odin w/video
    Then you will be able to make this mod. After I put my son down ill come back and explain what deodexed is.
    From my Galaxy Note 2 via Tapatalk
    RLLangley likes this.
    Thanks alot DroidXcon! Also if you could explain the differences between running what I have (stock) and running the deodexed rom would be. Would I also have to set up my phone again? Theming, apps, etc.
  4. #4
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Carrier
    Stock for now
    Quote Originally Posted by RLLangley View Post
    Yeah ill write it up in a bit. My baby fell asleep in my arms and I don't want to move. Yeah ill explain. .. And no you shouldn't have set Anything up again everything should stay the same. In the meantime you should use titanium backup and backup all apps and system data.
  5. #5
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Carrier
    Stock for now
    When you recieve your phone stock it is odexed, meaning that the system apps are split in two, an .apk file and .odex file. both are the same application just split in two.You can view this by going to the /system/app directory with a root file manager, you will see your apps(apk) with their odex counterparts;for example sms.apk and sms.odex. they do this so that booting is faster and it saves more space then having odexed files. When your phone boots it uses the odex files to anticipate the applications that it will be using so once the phone is on they are immediatly available, making your phone faster upon starting.
    Deodexing is the process of taking the odex file and recombining it with its apk counterpart. This only slows the phone down upon initial booting since the phone does not know what apps are there it will act sluggish at first. as you use the apps it will create whats called a dalvik cache and the phone will become more responsive and quick as it is suppose to be and upon next booting it will have built up this dalvik cache so it will know what to do and what to anticipate.
    Why is deodexing necessary? in order to modify an app it needs to be in one piece otherwise changes to an apk would be difficult since you would need to modify both apk and odex file piece by piece. By deodexing you can make modifications without difficulty (relative to your skill set). All custom roms are deodexed so that themeing to phone can be done, such as color layout, fonts , sizes can easily be made.
    If you flash the stock rooted rom that i directed you to earlier, you should not lose any of your current data or settings since that rom same as your stock rom but the .apk and .odex files have been recombined.'
    I hope this answer is clear enough
    itstrentb likes this.
    Thank you so much! I owe you a beer!
    DroidXcon likes this.
  7. #7
    Droid I was just reading this post And now I am wondering if my phone is deodexed by the simple 1 step root method that you posted. Would that work or do I have to unroot and then re root with the other method?
  8. #8
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Carrier
    Stock for now
    Quote Originally Posted by sudbury78 View Post
    The specific modification that is mentioned in this thread yes you need to be deodexed, which you are not. The modification you originally wanted puts all of the apps in the multiwindow bar. This application allows you to add and remove applications at will. If you would like to do this modification then yes you would simply need to flash the stock deodexed rom from this thread via odin [How to][VZW GNote2] Root/Rom via Odin w/video
  9. #9
    So I can stay as is and just have to deal with every app in my drawer in the multi window?? That would be terrible. OR, I can flash based on your link and then choose whatever-15 I want and then switch em up? Most importantly: I can go ahead with that Odin thread WHILE rooted via one step app?
  10. #10
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Carrier
    Stock for now
    Yes to all
  11. #11
    Okay. I think im okay with all the apps there because im quite frankly too worried to modify it more. Back to being cautious. Haha
    Sent from my SCH-I605 using Tapatalk 2
  12. #12
    Quote Originally Posted by DroidXcon View Post
    DroidXcon can you tell me how to get multiview mod on my phone? I can't understand the directions they have over at XDA. I need it broken down. Thanks. i am rooed with the deodexed.
  13. #13
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Carrier
    Stock for now
    Quote Originally Posted by allaboutnewphone View Post
    Are you unlocked or just rooted and deoxed. if you are unlocked its easier. but i can do a write up if you are not. Ill get to it as soon as i can i have alot of other projects going on at once right now. i hope you dont mind.
  14. #14
    I am just rooted and deoxed, I want to unlock but am scared I will mess up and brick my phone. but yes please do a write up on it and whenever you're ready, I'll wait. take your time, and thanks!
  15. #15
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Carrier
    Stock for now
    I'm almost done . Unfortunatly I can only find time to do these write ups between 3-5am but ill try to get it up asap
  16. #16
    I was just wondering if I did want to unlock my phone would I need to unroot my phone first?
  17. #17
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Carrier
    Stock for now
    no but during the process you may need to watch our your phone for the super user app to pop up asking for permission
  18. #18
    Oh, okay, thanks
  19. #19
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Carrier
    Stock for now
    Oh, okay, thanks
    aare you planning on doing this right now?
  20. #20
    No, I was just thinking about it. what are the benefits of getting it unlock rather than just staying rooted?
  21. #21
    Cant unlock my phone yet, Im using an windows computer from work and it don't allow me to download casual. so I guess I'll just have to wait until I get a hold of a non work pc. Do I need a pc to get all apps to multiwindow or can I just do it directly from my phone?
  1. Replies: 10
    Last Post: 04-08-2011, 12:54 PM
  2. Will the Epic be able to use Skype with 2.2 installed?
    By LS2982 in forum Sprint Epic 4G
    Last Post: 01-31-2011, 06:34 PM
  3. Are you able to use bluetooth while in the car dock?
    By katrina2475 in forum Motorola Droid X
    Last Post: 09-14-2010, 08:11 AM
  4. Any frustration not being able to use your fingernail for small buttons?
    By whitenack in forum General Help and How To
    Last Post: 06-04-2010, 02:40 PM
  5. Replies: 0
    Last Post: 04-20-2010, 04:15 PM
