1. celticfdguy's Avatar
    Last week I was playing around with some custom roms. I was unable to get onto the Verizon Wireless network after putting the rom on my phone, so I went back to stock (i downloaded the stock ROM off the web). I am currently on 4.1.1 (see screenshot below.) I found I was using the incorrect roms for my phone.
    My question is, after getting back onto the stock rom I no longer have the menu on the middle/left available on the screen (there was a toggle button you would click and a drawer would come out). I also notice when i hold down the back button for 2 seconds I am not prompted with the multi window feature...
    Any idea as to why this is? Did I download an older stock rom? Any help would be appreciated. I did disable a few apps from running but have re-enabled them all and still no luck.
    01-02-2013 12:09 PM
  2. DroidXcon's Avatar
    You Sure the toggle isn't there? You slide the toggles to the left? Where did you get this stock image. It appears to be correct though. What did you flash that made you lose access?
    From my Galaxy Note 2 via Tapatalk
    01-02-2013 12:16 PM
  3. celticfdguy's Avatar
    I'm an *****... figured out my issue. the multi window toggle button was unchecked... So that disabled it.
    01-02-2013 12:27 PM
  1. couple of issues...
    By Masterjakeway in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 12-23-2011, 05:01 PM
  2. A Couple of Issues
    By swissguy591 in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 06-13-2011, 01:32 PM
  3. When does the gallery "refresh" a couple of issues
    By BlackHawkA4 in forum Sprint Nexus S 4G
    Last Post: 05-30-2011, 09:40 PM
  4. Couple Of Issues
    By cybermonkeyssf in forum Verizon Fascinate
    Last Post: 09-27-2010, 03:55 PM
  5. Replies: 4
    Last Post: 06-18-2010, 09:11 AM
