04-20-2017 05:46 PM
72 123
tools
  1. kyraj1's Avatar
    I have A GN2 unlocked and i already have the phone switched to metropcs but the internets doesnt work i get calls and text but no internet please help
    03-15-2014 11:54 AM
  2. Jimmy Gipson's Avatar
    when i applied these 2 lines to the build prop the entire APN catagory disappeared from the mobile networks tab... now there is no tab labeled APNs... WTF?
    07-24-2014 10:35 PM
  3. lococho1's Avatar
    this work for me guys and I have a galaxy s4 from verizon using a t-mobile sim and it's working I just want to see the 4g lte sing instead H+ but the rest is perfec working
    08-27-2014 12:58 PM
  4. lococho1's Avatar
    You guys are so... good,
    08-27-2014 01:28 PM
  5. jfin79's Avatar
    I am on 4.4.2 locked bootloader but have root when these are applied to the build.prop all Apn settings go away any other ideas?
    11-18-2014 08:23 PM
  6. shadowlogic's Avatar
    I'm in the same boat, I'd like to use my note 2 on straight talk and have network access.. but as it stands I'm running I605VRUEMJ9 rooted. when i do everything this suggests it locks me out of my APN settings, i had an app for a "shortcut" to APN settings, but when i try to add an APN it doesn't save it when i click "settings/save" it's like it removes the APN entirely. i've heard of a bootloader unlock service hosted by a website, but i'm unsure of it being legit, i'd love to run cyanogen mod i have it on my S2 skyrocket.
    11-29-2014 08:44 PM
  7. shizumie's Avatar
    does anyone know the proper changes for this to work on Galaxy note 4. Just to make the APN editable.
    Thanks
    12-19-2014 11:29 AM
  8. zovial's Avatar
    Sir I have been trying to add apn in samsung stellar by verizon as per ur method.but the saved apn is not been detected..can u pls help?
    03-19-2015 12:47 AM
  9. taskr36's Avatar
    Sadly this didn't work for my Verizon HTC One (M7) running Android 4.4.3. I still can't add or edit the APN on this phone. Does anyone have any other suggestions?
    04-02-2015 05:10 PM
  10. titant's Avatar
    Hi
    I have the same problem with casio C811( version) , I cannot add APN , I would like TO KNOW if this tutorial is ok to use with this model
    Would you please guide me where to find any other tips concerning rooting or adding APN for casio c811. Thanks
    05-08-2015 06:33 PM
  11. titant's Avatar
    Hi
    could you please help, I would like to know if these apn setting are valid to use with casio c811
    Is there any solution for casio c811 which the APN has been locked by version
    thanks
    05-13-2015 06:50 PM
  12. norbl's Avatar
    I am using a VZW GN2 phone that I have activated on StraightTalk. After doing this hack, no APNs appear under mobile networks anymore.
    08-02-2015 07:42 PM
  13. mahendra suthar's Avatar
    I have note 3 Verizon.
    I wants use my Relaince cdma sim in it.but i m unable to use internet. when i m going to save apn ,nothing displayed in apn.
    I tried this apn editor but message displayed"failed to edit .
    Help me pls
    Indian user
    09-08-2015 10:21 AM
  14. srkswags's Avatar
    Dear,
    I got Samsung Galaxy S3 from eBay...Earlier it was on Verizon network. Guy sold me saying it is UNLOCKED and I can use GSM (T-mobile SIM card) in it. It is not taking SIM card (Invalid SIM error message while boot up). I checked APN and vzninternet service has been stopped and I am trying to enter new APN (T-mobile).
    Not even able to enter New APN. Will you be able to help me dear? I tried the method you mentioned. Somehow it is not working for me.
    Thanks in advance.
    Thanks
    Sonu
    09-08-2015 09:33 PM
  15. praneethkunda's Avatar
    Hi does this method works for Droid 4 too can any one suggest me plz
    09-18-2015 07:53 AM
  16. mel2000's Avatar
    nevermind just dont change the mmc or mnc...lol!
    I'm having the same issue. But what if those settings need to be changed (as mine do)?
    10-29-2015 10:22 PM
  17. Quoc Dung's Avatar
    hello
    This does not help. MCC still 46001 (China) and some apps gets conflicted due to wrong country code. Can you tell me how to edit fixed MCC in the configuration files somewhere in /system partition without APN? because i'm using a tablet without 3G and it has fixed MCC
    11-08-2015 05:13 AM
  18. bcwatson's Avatar
    Do I need to root my phone before I make the settings with the BuildProp Editor?
    12-17-2015 02:53 PM
  19. masterx1234's Avatar
    OMG!!!! ive been searching all over the internet far and wide and this finally fixed it for me! now i can change my apn and get my 4g lte data working
    12-22-2015 04:43 PM
  20. risingjo's Avatar
    hi can anyone please send me the setup wizard apk for brigadier??
    i rooted my phone via king root and deleted setup wizard apk to get rid of unknown sim message and forgot to copy it now every time i reboot it tells me to choose manually from providers list please someone help
    01-06-2016 09:59 AM
  21. yoelfriedman's Avatar
    hi,
    I tried this but it doesn't let me to save the buildprop.
    what am I supposed to do please?
    02-19-2017 11:15 AM
  22. 10Blackwolves's Avatar
    Can someone please help me i tried the same thing for my ellipses 7 tablet from verizon and it didnt work their still blocked i dont know what to do. I almost wanna throw the thing againt the wall. I am trying to use it with cricket if that helps
    Alright guys i found out what happened to us and it can be workes around after 2 weeks of reading code and the scripts you can shut it down and return back to normal function with the jelp of build prop editor
    I hope this helps everyone
    Attached Thumbnails [MOD] Add APN editor to System Settings-screenshot_20170420-203241.png
    04-20-2017 05:46 PM
72 123
  1. Erase phone contents to factory settings.
    By ushneb in forum HTC Droid Eris
    Last Post: 04-30-2016, 10:18 AM
  2. File System set to read only
    By ochness in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 05-07-2014, 11:10 AM
  3. Replies: 12
    Last Post: 02-17-2013, 11:38 AM
  4. System settings ui mod?
    By truthfamilyfaith in forum Verizon Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 12-29-2012, 08:44 PM
  5. Google adds spare battery to order sheet...
    By LCW in forum Google / HTC Nexus One
    Last Post: 03-17-2010, 02:06 PM
