1. j.glik14's Avatar
    Finally rooted and question about the rom.
    How do I get the clock to the right and not centered?
    Sent from my SCH-I605 using Tapatalk 2
    01-16-2013 08:21 PM
  2. pmjj's Avatar
    After you have installed "Beans" I do not know that you can move it. When you first flashed, before it installs it asks preference questions. I think you have to set it at the beginning during those questions.
    01-16-2013 09:43 PM
  3. PsYcHoNeWb's Avatar
    If you flashed Beans and you selected "center" for the clock then the only way to get it back to the right side would be to reflash the ROM.
    01-17-2013 12:22 PM
  4. j.glik14's Avatar
    And if I reflash it would I need to wipe first?
    01-17-2013 03:39 PM
  5. crl95's Avatar
    wipe cache and dalvik cache and it should be fine but if you get any errors do it again and also do a factory reset
    01-17-2013 04:27 PM
  6. DroidXcon's Avatar
    ^^ so proud
    crl95 and dubge like this.
    01-17-2013 04:31 PM
  7. jengobengo's Avatar
    So if I'm going to update from Beans 4, and I'm on the SD card swap mode (where my SD card is recognized as the main phone memory), how do I ensure my app data and photos carry over?
    Once I know this I will definitely check out CLEAN and future ROMs.
    01-17-2013 10:27 PM
  8. j.glik14's Avatar
    Wiped dalvik cache and working great. Thanks for the help!
    crl95 likes this.
    01-22-2013 05:36 PM
  9. Droid_Evo_8's Avatar
    Build 7 is up.
    crl95 likes this.
    01-24-2013 01:33 AM
  10. j.glik14's Avatar
    Is a wipe needed from build 6-7?
    01-24-2013 02:37 PM
  11. DroidXcon's Avatar
    You can always try without a factory wipe ..if it gives you problems you can always go back and wipe. But always make sure you do at least a dalvik cache wipe
    From my Galaxy Note 2 via Tapatalk
    01-24-2013 04:10 PM
  12. crl95's Avatar
    The first time I did this I did a dirty install and had no luck then did a clean install thought I was in luck but when I woke up and tried to unlock my phone the screen would turn on for a second and then go back off again. I installed it clean again and went to school and when it was inactive for a few hours I had the same issue. Finally I got it to unlock and changed the AOSP lock screen off and it has been fine since then. Do you have any idea whats wrong with the lock screen on AOSP for me?
    01-24-2013 04:35 PM
  13. DroidXcon's Avatar
    No idea . For future refrence try doing a system wipe then reinstall the rom again. Then boot up sometimes it fixes stuff like that
    crl95 likes this.
    01-24-2013 04:39 PM
  14. j.glik14's Avatar
    tried to install and stuck in boot loop. how can I access the bootloader when the phones off (URGENT)
    01-24-2013 05:57 PM
  15. crl95's Avatar
    pull the battery out put it back in and hold down volume up power and home button... hope that was fast enough response haha
    01-24-2013 05:59 PM
  16. DroidXcon's Avatar
    Vol dwn +home button+power
    01-24-2013 06:00 PM
  17. j.glik14's Avatar
    that puts me in odin... what next?
    01-24-2013 06:01 PM
  18. crl95's Avatar
    thought it was volume up?
    DroidXcon likes this.
    01-24-2013 06:02 PM
  19. DroidXcon's Avatar
    Oh sorry vol up+home+power then
    01-24-2013 06:02 PM
  20. crl95's Avatar
    did you listen to me or droid
    - - - Updated - - -
    Yessssss! I finally beat you to something and got it right hahaha
    01-24-2013 06:02 PM
  21. j.glik14's Avatar
    this worked. awesome thanks!
    01-24-2013 06:03 PM
  22. crl95's Avatar
    can no one see my replies to threads lol whenever I do no one answers haha
    01-24-2013 06:11 PM
  23. DroidXcon's Avatar
    Did you say something?...... j/k , good job you did beat me to the punch i must be having an off day
    crl95 likes this.
    01-24-2013 06:15 PM
  24. crl95's Avatar
    Funny how even on an off day for you when you answer later and wrong the first time you still get the thanks haha.... I guess thats a perk of having your name in orange
    01-24-2013 06:27 PM
  25. DroidXcon's Avatar
    After 10,500 posts people start to think you know what you're talking about.
    crl95 likes this.
    01-24-2013 06:29 PM
  1. Question about root and jellybean
    By TimV28 in forum Verizon Galaxy S III
    Last Post: 12-18-2012, 06:11 AM
  2. A question about build quality
    By Bob-B in forum Droid RAZR MAXX HD
    Last Post: 11-20-2012, 01:24 PM
  3. Questions For Devs about ROM building
    By scrosler in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 06-03-2011, 01:39 PM
  4. Question about build material on the Xoom.
    By Low023 in forum Motorola Xoom
    Last Post: 02-17-2011, 08:57 PM
  5. quick question about Cyanogen Nightly Builds?
    By ItsAllAndroid in forum G2 Rooting, ROMs, and Hacks
    Last Post: 02-03-2011, 09:46 PM
