Stuck on boot logo AOKP! Need help!
I just used Adam Outler's new root/unlock method and flashed the latest AOKP build. Dumb*ss me forgot to wipe cache/dalvik factory reset and now it won't boot up. Just stuck on the nexus boot logo for about 20 min now. Anything is appreciated, Thanks!
Re: Stuck on boot logo AOKP! Need help!
Just boot into recovery and do the wipe
From my Galaxy Note 2 via Tapatalk
I tried that (if by recovery you mean vol down+home then power). I just get the same downloading... do not turn off target screen I got before I rooted/unlocked. Not TWRP. Is there a different method to boot directly into TWRP?
Do the same thing but volume up
Thanks a million! I feel like such an ***** (I'm a major noob at this if you can't tell). You've got a donation coming your way my friend. You really got me out of a jam.
Thanks glad it worked out. Let me know if you need any other help
Hi there,
I did the wipe (using CWM, wiped everything including cache, SD, everything) and I am still stuck on the logo boot screen. Do I need to flash through Odin or another way to get my phone up?
