Results 1 to 4 of 4
    Donti's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Stuck in Boot Loop Help Needed
    I rooted my note 2 out of the box and grew tired of seeing ota updates pop up so i went back to stock with odin every thing went well till i acepted ota updates now im stuck at boot loop and cant go back to stock odin fails after it says nand write then fail i also dont have a recovery to go to some one please save my week i been trying to get this back up for 3 days now with no luck
  2. #2
    webbie2's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock Android 4.0.3
    Default Re: Stuck in Boot Loop Help Needed
    I would boot into Clockwork MOD do this in order:
    wipe date/factory reset
    Format/system
    Flash Back up from recovery
    Hopefully this will work for you. Let me know if you get this working.
    Donti's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by webbie2 View Post
    Format/system
    how do i do that when the phone wont resprond? and power plus vol down dosnt do anything
    Donti's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    update i tried to put baseline recovery on to the phone with odin and a pit file and i got a little further im now getting sboot.bin then fail then if i try to put stock rom on to phone it fails at sboot.bin
  1. Evo 4G LTE stuck in boot loop? Or bicked? Not sure. Need help
    By Gabriel Baer in forum HTC EVO 4G LTE
    Last Post: 01-17-2013, 08:48 AM
  2. LG OV stuck in boot loop. help please.
    By shadow51234 in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 07-21-2012, 12:33 PM
  3. Can't flash new ROM - can't restore backup - stuck in BOOT LOOP. HELP!!!
    By lj5625 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 01-18-2011, 01:01 AM
  4. HELP!! Lost SD card and all nandroid backups, now stuck in boot loop
    By handbra#AC in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 09-22-2010, 10:24 AM
  5. LG OV stuck in boot loop. help please.
    By in forum Virgin Mobile Optimus V
    Last Post: 12-31-1969, 07:00 PM
