Results 1 to 3 of 3
    Default Issue with CM 11/Android 4.4
    Not sure if anyone else has it installed, but having an issue with it.
    I've installed both the 11/11 version and 11/23 version. My phone will consistently freeze up at random times and I can't figure out why.
    Anyone know a reason why this may be happening?
  2. #2
    Default Re: Issue with CM 11/Android 4.4
    I scanned through the XDA forum and didn't see any freezing complaints. Others are having the proximity sensor stay on like a light. Which may be causing battery drain
  3. #3
    Lodingi's Avatar
    Posts
    Global Posts
    787 Global Posts
    Make sure you format your internal storage before flashing CM11. You also need to flash PA_GAPPS for your Google Services. The standard GAPPS will cause problems.
  1. GS3 4.3 Issues.
    By Biga173rd in forum Sprint Galaxy S3
    Last Post: 12-20-2013, 12:15 PM
  2. Replies: 20
    Last Post: 12-04-2013, 11:58 AM
  3. AT&T Samsung Galaxy Note 3 - Wi-Fi Issues
    By txmarine801 in forum AT&T Samsung Galaxy Note 3
    Last Post: 11-30-2013, 12:06 PM
  4. KitKat 4.4 Google Play Issue - Help needed!
    By odoliam in forum Google Nexus 4
    Last Post: 11-26-2013, 03:05 AM
  5. Emergency call issue
    By gamefreak715 in forum Motorola Droid MAXX
    Last Post: 11-25-2013, 09:12 AM
B
