1. jbomb11's Avatar
    So I was running CM 10 and 11 back and forth trying to decide which I preferred.
    Both were giving me issues with picking up LTE on my Verizon Note 2. Checked and my phone info is still in there under the settings so I dont think its a SIM card issue.
    Long story short I either was getting no data connection or no LTE. Wasn't even getting the option to select LTE in the network mode in the ROM settings.
    I want to install OMNI KIT KAT ROM and I am getting no data.
    Any thoughts or recommendations?
    01-31-2014 12:24 PM
  2. VDub2174's Avatar
    Have you tried flashing another modem?
    [RADIO][CWM] Radio Images - xda-developers
    01-31-2014 12:29 PM
  3. jbomb11's Avatar
    which one would I use for vzw note 2? Also if it didnt work I would just restore back to the latest backup where at least 3g is working right?
    01-31-2014 12:50 PM
  4. VDub2174's Avatar
    They're all for the VZW Note 2 so you can use any of them. Yes, just do a backup and if you don't like the results you can just restore to the old modem.
    01-31-2014 01:24 PM
  5. jbomb11's Avatar
    Thanks VDub! Ill try it out and check back with ya.
    01-31-2014 01:54 PM
  6. VDub2174's Avatar
    No problem
    Let us know how things go for you.
    01-31-2014 02:03 PM
  7. jbomb11's Avatar
    Got CM11 fired up and working fine - sticking with this for now!
    Much appreciated
    VDub2174 likes this.
    01-31-2014 02:26 PM
  8. VDub2174's Avatar
    Awesome!!
    01-31-2014 02:33 PM
  1. [ROM+Kernel][CM-11.0][4.4.4][OS2SD/internal][f2fs]bigsuperROM-thunderc-4.4.4
    By bigsupersquid in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 01-31-2017, 10:11 AM
  2. With the help of Custom ROMs, is it possible for Nexus 7 (2013) to make phone calls?
    By Hendra Anggrian in forum Google Nexus 7 Tablet (2013)
    Last Post: 05-15-2014, 11:06 AM
  3. Data sync causing lag??
    By Sincs in forum LG G2
    Last Post: 02-07-2014, 12:29 PM
  4. Galaxy S4: Home Wifi Issues!!!
    By SmashBox85 in forum Samsung Galaxy S4
    Last Post: 02-01-2014, 11:48 PM
  5. Issues with my new international LG G2
    By Maged Samuel in forum LG G2
    Last Post: 02-01-2014, 09:00 AM
