Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By wizzrah
    Default Verizon Note 2: Safest way to unroot
    I'm running Android 4.1.1, baseband I605VRALJB. I rooted using Exynos Abuse. What's the easy and safe way to unroot so I can go back to stock?
    Thanks
  2. #2
    wizzrah's Avatar
    Posts
    Global Posts
    4,726 Global Posts
    Carrier
    Kitkat
    Default Re: Safest way to unroot
    Quote Originally Posted by BudmanNC View Post
    Thanks
    If you are using SuperSU, it has an "unroot" option built in.
    Synycalwon likes this.
    So....I just uninstall Exynos Abuse and reset it back to stock? I'm doing this so I can turn this phone back in. I want it to be just like new as far as the operating system.
  4. #4
    I'm rooted using the same OS version (I605VRALJB) with SuperSU. Assuming you have it too, there is a "Full unroot" option in SuperSU. Launch the app from your app drawer, then under "Settings" scroll down; the option is near the bottom. It will delete SuperSU from the system removing root. You could then do a master factory reset to put the system back to a clean default state (doing so will also remove the Exynos Abuse app).
    Yes, I do have SuperSU. Sounds pretty simple. Thanks.
  6. #6
    wizzrah's Avatar
    Posts
    Global Posts
    4,726 Global Posts
    Carrier
    Kitkat
    Should be. Let us know if you run into any problems!
  7. #7
    Quote Originally Posted by wizzrah View Post
    I too am running Android 4.1.1, baseband I605VRALJB but have Superuser instead of SuperSU. I see an option for "temporary unroot" but not full unroot. What is the easist option for me to unroot and go back to stock?
  8. #8
    Quote Originally Posted by beefchopper View Post
    You could use a file manager such as ES File Explorer (with its root features enabled to get to the "system" directory) and delete the following files (then reboot phone):
    /system/xbin/su
    /system/app/Superuser.apk
  1. Replies: 3
    Last Post: 06-03-2014, 12:08 PM
  2. How to get my text msg icon to blue on my LG G2?
    By Kimberly1998 in forum Verizon LG G2
    Last Post: 03-27-2014, 10:18 AM
  3. Google play launches when I try to text someone
    By Cicely Watkins in forum Sprint Samsung Galaxy S4
    Last Post: 03-24-2014, 05:25 AM
  4. AT&T Note 3: Need to use on T-Mobile
    By Denton Yorkirons in forum Samsung Galaxy Note 3
    Last Post: 03-23-2014, 09:30 PM
  5. Replies: 1
    Last Post: 03-23-2014, 08:23 PM
