Razr Maxx
It's a awesome phone with the best by far battery life!!
Just would like a bigger screen, faster, jelly bean, basically the best thing out and i think that's the note 2!!
To bad they didn't make the battery bigger with a screen that size. The screen uses most of the power so of course it needs a big battery but it's scrappy smaller than the maxx which has only a 4.3 screen. I don't think battery life will be anything to brag about
SaltySteve:
Battery life of high performance phones is probably my first priority when considering a new device. It doesn't matter how amazing a phone is if it can only be amazing for 4 hours before it has to be plugged in. Or everything has to be turned down so low for it to make it through the day that it isn't amazing anymore.
I am one of the few happy original Thunderbolt owners because I got an extended battery from the beginning. My phone has met my expectation from the start and done everything advertised, albeit with the hump in its back.
In leaving my T-bolt I want something that can last all day without having to turn all the features off.
Coming from the Razr Maxx, I'm surprised you aren't considering the Maxx HD as I am. It has everything you liked about the Maxx but with a bigger, better screen.
Maybe you, like I, are waiting to see how the battery performs on the GN2.
The bigger screen, better camera, and advanced features make the GN2 better than the Maxx HD in my humble opinion, IF, THE BATTERY LAST A FULL DAY.
Above, you wished that it had a bigger battery but it is significantly bigger than the original Galaxy Note.
The GN1 only carries a 2500 mAh battery and generally makes it through the day according to most posters in that forum. The GN2 has a 3100 mAh battery and has gotten glowing reviews on that forum. The problem is those GN2 phones are on networks with little to no super high speed but super battery draining LTE.
The true test will be the Verizon launch where most have full time LTE. If the GN2 performs well then bye-bye T-bolt.
Sent from my ADR6400L using Android Central Forums
