1. kilofoxtrot's Avatar
    I guess I should ask first, as I am referring back to my GSM SIM days long ago. Back in those dark days with AT&T , I had a Nokia E71 and N85 (the E71 to this day is one of the best built phones I have ever owned) and I would just pop my SIM card in whatever phone I felt like for that day or time of day and go.
    Can you do this with Verizon SIMs and not have to call CS?
    I would like to have my S3 and N2 be setup as nearly identical as they can (apps and UI items), allowing for the N2's special capabilities of course.
    I would love to be able to swap phones with by just moving my SIM card to the phone I felt like using without involving a call to customer service.
    I am using Nova Prime launcher. I plan on using the backup/restore option via dropbox/email myself/beam etc etc to keep both phones looking the same whenever I make a change.
    11-10-2012 07:31 AM
  2. bigguy_132's Avatar
    Far as I know as long as the SIM cards are the same size drop it in and go
    kilofoxtrot likes this.
    11-10-2012 08:32 AM
  3. Markster1's Avatar
    I used to do this with my OG Incredible and Incredible 2 but the original has been acting funny ever since the latest update so will set up the note 2 as identically as i can with incred 2.
    The Nottinator
    11-10-2012 01:01 PM
  4. ibcop's Avatar
    If you want to swap devices, you can do it online via your Verizon account page. You select the phone you what to swap, enter the new IMEI number of the other device, and you're good to go. I do it all the time between my wife's S3 and her Iturd.
    Unless you are overseas, you won't be using the SIM anyway - it will be based on the IMEI number.
    11-10-2012 03:39 PM
  5. Markster1's Avatar
    Just dial *228 from the phone you want to activate then the phone number you want to use and that's it.
    The Nottinator
    11-10-2012 05:36 PM
  6. ptm88's Avatar
    4g phones just require the sim swap, and the system automatically updates the IMEI. 3g you can do *228
    11-10-2012 06:37 PM
  7. Markster1's Avatar
    I've got a Sim card in the incredible 2. Any way i can i can swap with the note 2?
    The Nottinator
    11-11-2012 12:47 PM
  8. MrSmith317's Avatar
    The Nottinator
    I didn't think the Dinc2 was LTE. I had to trade my standard 4G sim for a micro-sim coming from the Rezound -> Galaxy Nexus and that one works and is currently living in my SGS3.
    11-12-2012 01:24 PM
  9. skinnytoo2's Avatar
    From what I understand, with a 4G SIM, you can just pop it in the new device and it will activate it with same phone number in a few mins
    11-12-2012 11:31 PM
  1. Anyone dislike their S3?
    By guinnkevinr in forum AT&T Galaxy S III
    Last Post: 10-14-2012, 10:16 PM
  2. Has anyone been able to use their TB as a remote for Fios?
    By ggrr8t in forum Verizon HTC Thunderbolt
    Last Post: 08-17-2011, 07:19 PM
  3. Does anyone use their Verizon Galaxy Tab as a mobile hotspot
    By jingorm in forum Samsung Galaxy Tab
    Last Post: 06-13-2011, 12:24 AM
  4. Anyone use their EVO as their sole GPS?
    By PM-Performance in forum HTC EVO 4G
    Last Post: 06-30-2010, 05:24 PM
  5. Anyone noticing their flash going off too soon with the camera?
    By GenericMessage in forum Motorola Droid
    Last Post: 06-10-2010, 09:46 AM
