1. Casey Cheung's Avatar
    Anyone know answers to these questions?
    Will it support Flash video playback on internet sites?
    Will there be a 64GB internal model? Or only 32GB?
    What is the full retail price for the largest GB size model?
    Thanks!
    Casey
    11-12-2012 12:31 PM
  2. MrSmith317's Avatar
    Thanks!
    Casey
    Every Android phone can play flash with the flash plug-in. You just need to side-load the app. It's not optimized for JB(Android 4.1/4.2) but it will work. I think there's only one option(16GB) and the retail that I was quoted was $699. I believe you can look that up on Verizonwireless.com
    Casey Cheung likes this.
    11-12-2012 01:16 PM
  3. brentj's Avatar
    It does not come with Flash installed, but if you install Flash it works fine on internet sites, or at least my Sprint version does. My prior post with links:
    Can't Play CNN video even though I downloaded Adobe Flash 11
    11-12-2012 01:18 PM
  4. Casey Cheung's Avatar
    Thanks! I could have sworn I saw something about a 32GB version, in addition to the 16GB. If there will be a 32GB version, I'd rather wait for that. That would be similar to the Galaxy S3 debut, whereby the 16GB version came out first, and the 32GB followed weeks later.
    11-12-2012 01:59 PM
  5. 4 Star General's Avatar
    Why pay a extra $100 for the 32g device, when you can get a 16g sd for $30 or a 64g sd for $80...simple math to me.
    11-12-2012 02:56 PM
  6. ibcop's Avatar
    If you look around, you can get a Class 10 64gb card for 59 bucks.
    Here is one at Amazon:
    Amazon.com: SanDisk Ultra 64 GB MicroSDXC Class 10 UHS-1 Memory Card with Adapter (SDSDQU-064G-AFFP-A): Computers & Accessories
    The Class 6 is also available, but is 94 cents more than a Class 10.
    Amazon.com: SanDisk 64GB Mobile Ultra MicroSDXC Class 6 Memory Card with SD Adapter - Retail Packaging: Computers & Accessories
    Both come with the adapters.
    dragonsamus likes this.
    11-12-2012 04:19 PM
  7. Casey Cheung's Avatar
    Actually, I already recently bought a 64GB Sandisk Ultra MicroSD card from a local Best Buy store a couple weeks ago for $49.99 which I'm currently using on my Verizon Motorola Razr Maxx. The reason I want the larger 32GB Note 2 is because I want a larger available internal memory, since many apps can only run internally as opposed to from the card. This plus the fact that the operating system usually takes up about 1/2 of the internal memory anyway, which means the 16GB version probably will only have something like 8GB free for the user. Myself, I'd rather pay the extra $$ to get the larger internal memory. If I had the Note 2 32GB internal version, I would then swap out my 64GB card from my current Razr phone to use for the Note 2.
    11-12-2012 04:25 PM
  8. ibcop's Avatar
    My first S3 was a 16gb model - out of the box, the end user had just over 12gb available. My 32gb has 26gb as it sits right now with my configuration. I seriously doubt you'll have any issues with a 16gb model.
    No way the OS takes up half the memory.
    11-12-2012 04:42 PM
  9. nlitenme's Avatar
    Supposedly, 10.2 GB internal storage is available on the 16 GB model - Samsung Galaxy Note II (Verizon) Specs, Features (Phone Scoop)
    11-12-2012 05:08 PM
  10. ibcop's Avatar
    Must be more apps - but 10gb is still a lot just for apps. I'd rather a 32gb as well (just for re-sell purposes) but it'll do.
    Add a 64gb card and you're good.
    11-12-2012 06:48 PM
  11. Raptor007's Avatar
    With today's announcement of the Droid DNA being 16GB as well it seems Verizon is pushing hard for people to have limited storage and go the cloud/streaming way which is going to be costly if you don't have unlimited data. The carriers if they had a soul (which they don't) would go the 32GB route as a minimum. I think the lack of microSD slots is going to be happening more and more as we move forward with Android 4.2 since it doesn't support storing apps there. OEM's may eliminate them to cut cost, dumb the devices down for the masses and offer fewer yet simpler versions.
    I'm fine with that but the tablets better start being 32GB and 64GB only, why bother with 16GB.
    11-13-2012 11:57 AM
  1. Evo is awesome but some questions please
    By shin.andy in forum HTC EVO 4G
    Last Post: 06-05-2010, 02:33 PM
  2. Launcher Pro...Questions! Please help!
    By Vaffanculo403 in forum Android Apps
    Last Post: 06-01-2010, 04:46 PM
  3. questions please answer!!!!!
    By abocornwall in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 03-09-2010, 07:15 PM
  4. Sholes 2.0.3 question, please help!?
    By stefanl in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 02-12-2010, 09:27 PM
  5. Really dumb questions, please be kind
    By macjazzy in forum General Help and How To
    Last Post: 02-02-2010, 02:57 PM
