11-30-2012 01:58 PM
68 123
tools
  1. MiXoLoGiSt's Avatar
    I went to Best Buy and they just got in the Demo model of the Note 2 for Verizon.
    I just wanted to let you know of some changes I noticed compared to other Note 2s.
    First thing is the digital clock widget is gone. This is the clean simple clock widget you see just the time and date on. This was kind of disappointing to me.
    Second thing is there is no wifi toggle on the top of the notifications. Instead it has an ongoing notification which can kill battery life faster.
    The third thing I want to note (no pun intended) is that Verizon's version DOES in fact have the multitasking ready to go. You won't have to wait for an update for this feature.
    I wish I could have tested reception but Best Buy doesn't activate any of their demo phones.
    Who? and geekaren like this.
    11-15-2012 05:14 PM
  2. DroidXcon's Avatar
    Toggles can be added, and im sure the clock can be made available easily. What is the notification specifically?
    11-15-2012 05:18 PM
  3. MiXoLoGiSt's Avatar
    I understand toggles can be added but that's not the point. The point was to give differences in the Verizon version from other versions. Same goes for the clock widget. Clock widgets are a dime a dozen but I really liked that specific one and I'm not sure why Verizon would have possibly messed with a clock widget.
    The notification is an ongoing notification telling you which wifi network you are connected to or telling you there are wifi networks available.
    11-15-2012 07:26 PM
  4. chevyman29's Avatar
    did you notice if it had the screen brightness control in the pull down menu ? i really wish my s3 had that
    11-15-2012 07:40 PM
  5. LuvHorses's Avatar
    It does as I saw pics of the that screen online.
    Here:
    http://www.droid-life.com/2012/11/14...st-buy-stores/
    chevyman29 and wpd805 like this.
    11-15-2012 07:54 PM
  6. kjung7's Avatar
    The Verizon SGS3 also has that ongoing wifi notification instead of a toggle. You get used to it after awhile. If you really don't like it you can root and add different toggles to the notification center.
    Sent from my SCH-I535 using Tapatalk 2
    11-16-2012 09:52 AM
  7. ibcop's Avatar
    Yeah, it does. You can also enter a code and turn it off. I found the code in the S3 thread.
    geekaren likes this.
    11-16-2012 10:18 AM
  8. superlawyer15's Avatar
    can you share this "code" with the rest of us please..
    11-16-2012 10:25 AM
  9. ibcop's Avatar
    This will work on the S3, but not sure about the GN2. I cant take credit for it, but here it is:
    Open the dialer and enter the following code: *#6335623#
    This will open "HiddenMenuWifiOffload" menu.
    Select "Disable WifiOffloading"
    Press "OK"
    Done!
    11-16-2012 11:36 AM
  10. ecs180's Avatar
    What other codes are there?
    11-16-2012 12:41 PM
  11. Irish1842's Avatar
    Just played with a Verizon demo unit at Best Buy and noticed that you cannot continuously scroll though home screens or the app drawer. When you hit the last screen you just get the little rubber band effect and cannot continue on to the first screen. I tried to figure out if there was a setting to change this, but couldn't find one. Can that be changed, or did Verizon gimp that feature for some reason?
    11-17-2012 02:38 PM
  12. lembowski's Avatar
    Press "OK"
    Done!
    Interesting have to give this a try.
    11-17-2012 07:03 PM
  13. NHBass39's Avatar
    Why does that matter? Honestly NBD if you ask me.
    11-17-2012 07:22 PM
  14. Irish1842's Avatar
    It isn't a big deal, but why remove even a subtle convenience feature that is standard on the rest of the galaxy line? Seemed odd to me.
    11-17-2012 07:36 PM
  15. pool_shark's Avatar
    It's ridiculous that Verizon put the stupid ongoing notification on the Note as they did on the SG3.
    I read that they didn't do that to the Razr line. Users should not have to root or install software or find codes to disable a feature that Verizon somehow deemed necessary.
    I know it won't happen, but that's enough for people to tell Verizon to screwed themselves and not purchase this from them until they make that an option as it has always been.
    I read that the code in the above post only stops the pop-up, in order to remove the persistent notification, you have to have root.
    [HACK] Remove WiFi reminder - xda-developers
    11-17-2012 07:36 PM
  16. superlawyer15's Avatar
    i've read on other forums that this notification is not limited to the verizon note
    users with ATT have been reporting the same thing
    11-17-2012 07:54 PM
  17. Irish1842's Avatar
    Does the wifi notification only show up when you turn wifi off, or is it always present?
    Edit: currently deciding between carriers and want to make sure I am clear on any hardware/software differences
    11-17-2012 08:02 PM
  18. superlawyer15's Avatar
    if you have a choice of carriers go w/ ATT
    verizon has the best network, but they pull crap like this all the time and it gets old quick
    11-17-2012 08:05 PM
  19. Mellimel22's Avatar
    If u talking about this one with the question mark then JUST TURN OFF WIFI LOL duh
    Sent from my EPIC WHITE SGS2 Rockin CM10 4.1.2 using Tapatalk 2
    11-17-2012 08:10 PM
  20. pool_shark's Avatar
    I did see one post about it on AT&T.
    11-17-2012 08:12 PM
  21. pool_shark's Avatar
    From what I've read, the pop-up comes on anytime you're not connected to wifi, but the notification is there at all times whether you're connected or not.
    11-17-2012 08:14 PM
  22. pool_shark's Avatar
    If u talking about this one with the question mark then JUST TURN OFF WIFI LOL duhhttp://img.tapatalk.com/d/12/11/18/5uvyra8e.jpg
    Try reading the complaints next time.
    11-17-2012 08:18 PM
  23. NHBass39's Avatar
    Just turn WIFI off. Problem solved. I don't use WIFI anyway. I'm unlimited.
    11-17-2012 08:46 PM
  24. Irish1842's Avatar
    I'm not
    11-17-2012 09:07 PM
  25. pool_shark's Avatar
    Turning wifi off doesn't fix the problem. The notification is there all the time whether wifi is on or not.
    That's why I said read the complaints.
    11-17-2012 09:16 PM
68 123
  1. One thing I've noticed on the Note II
    By OceanView in forum Samsung Galaxy Note 2
    Last Post: 11-23-2012, 07:36 PM
  2. Samsung Galaxy Note 10.1 On Verizon?
    By FSchmitthammer in forum Samsung Galaxy Tab 2 10.1
    Last Post: 11-10-2012, 06:21 PM
  3. Some insider leaking Info on the Note 2 in a weird way.
    By MannyZ28 in forum Samsung Galaxy Note 2
    Last Post: 09-13-2012, 10:31 AM
  4. Galaxy Note on Verizon?
    By ShaggyKids in forum Samsung Galaxy Note
    Last Post: 08-23-2012, 10:24 AM
  5. Galaxy note on verizon?
    By taylorz_412 in forum The Android Central Lounge
    Last Post: 03-24-2012, 11:51 PM
