Results 1 to 16 of 16
    jodyberry's Avatar
    Posts
    Global Posts
    381 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default What's the best MicroSD 32GB Card for Note 2?
    Hi all,
    I've read a bunch of scattered threads about MicroSD cards but would like to get some opinions on them here.
    Mainly I was wondering if the Note 2's 1080p recording capability requires a particular speed memory card? I haven't bought a card in a while and I'm out of the loop on specs these days.
    Some people have posted a great buy from Best Buy on a 32GB card - SanDisk Ultra 32GB microSDHC Class 10 Memory Card SDSDQUI-032G-A11 - Best Buy
    But some reviews got me thinking about throughput speed needed to do continuous 1080p recording. Someone was saying this card has ups and downs as far as speed. And then Joe The Insider mentioned Samsung cards being more consistent.
    Maybe someone can school me on the specs I should be looking for in a 32GB card for the Note 2.
    If it's not a big deal, I'll just get the one from Best Buy.
    Thanks all!! And Happy Thanksgiving!
  2. #2
    ibcop's Avatar
    Posts
    Global Posts
    6,065 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Default Re: What's the best MicroSD 32GB Card for Note 2?
    Quote Originally Posted by jodyberry View Post
    Hi all,
    The Class 10 card is about the best you can get, as far as I know. Some have said the Class 10 is overkill for smart phones but there really isn't a big price difference between the Class 10 and Class 6. I have the SanDisk 64GB Class 10 and it's good for me.
    I say if you can snag one, get that puppy.
    jodyberry likes this.
  3. #3
    Raptor007's Avatar
    Posts
    Global Posts
    6,963 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I would agree, for the price difference between a 32GB and 64GB card you might want to consider the 64GB class 10, I got mine from amazon.com for under $60. Crazy how cheap they are now compared to a year or so back and what we all paid then.
  4. #4
    Markster1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't know how reliable Joe's info would be on that aspect. In another thread he ordered an sd card instead of micro sd.
    The Nottinator
  5. #5
    Bobman's Avatar
    Posts
    Global Posts
    228 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Go to Amazon and get the 64GB micro-SD for $38 now! Amazon.com: SanDisk Ultra 64 GB MicroSDXC Class 10 UHS-1 Memory Card with Adapter (SDSDQU-064G-AFFP-A): Electronics
    This is the price of the "lightning deal" but apparently they lowered the regular price to it too. Not sure how long it will last.
  6. #6
    Joe the Insider's Avatar
    Posts
    Global Posts
    1,391 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Markster1 View Post
    The Nottinator
    I copied the wrong link, i know the difference bet ween the 2.
    Sent from my SCH-I535 using Android Central Forums
    redsoxfan2133 likes this.
  7. #7
    ibcop's Avatar
    Posts
    Global Posts
    6,065 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Quote Originally Posted by Bobman View Post
    Yep, picked up another one.
  8. #8
    Markster1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Joe the Insider View Post
    Ok, it happens.
    The Nottinator
    jodyberry's Avatar
    Posts
    Global Posts
    381 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks all!! I ended up getting the 32GB sandisk for $17.99.
    I thought about the 64GB but its another 20 bucks and I have already overspent on my other accessories!!
    Plus, on my DROID X I only have 16GB and have never maxed it out (not a heavy gamer or mp3 person )!
    Sent from my DROIDX using Tapatalk 2
  10. #10
    OffSpot2's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Is it better to have a 16g phone and a 32g card or a 32g phone and a 16g card? Are they the same? I guess what I am asking is this: If I move a game (or other app) to the sd card, does it run at the same speed when I use it as if it were on the phone? Does moving things to the sd card free up space on the phone and help it run faster? Are there some things that should be stored to the sd card, but not others? This has always bugged me not knowing...
  11. #11
    ibcop's Avatar
    Posts
    Global Posts
    6,065 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Quote Originally Posted by OffSpot2 View Post
    You can't store apps on the SD Card. Photos, music, movies, etc on your SD Card. All the apps are stored on the internal memory.
    - - - Updated - - -
    Good deal!!
  12. #12
    Raptor007's Avatar
    Posts
    Global Posts
    6,963 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    With rooting there is a work around that will let you make the SDCard the primary storage, but I'm not sure I am going to go that route. Also I thought the add on data for games still goes to the storage card, is that not the case? Its hard to keep it all straight sometimes with so many threads and sites to read.
  13. #13
    Jude526's Avatar
    Posts
    Global Posts
    5,945 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    U had the the thunderbolt. Cane with a 32gig. have the rezound using the same card. Will on the note2 as well
    sent from either my HTC Rezound or my Samsung Galaxy 10.1 tablet
  14. #14
    amadeus303's Avatar
    Posts
    Global Posts
    4 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Is there a difference between this card and the "Mobile" version? On the Sandisk site, it looks like the "Mobile" version includes a "Memory Zone" app for Android that simplifies file management.
  15. #15
    fwhomeboy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Quote Originally Posted by amadeus303 View Post
    Question : Is there a program that will read what type of SD card is installed ? Like CPUID ?
  16. #16
    Greg Agan's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Yes apps can be saved to the sd card all my apps are saved on my card and when i transfered my memory card to my note 2 all my apps loaded automatically
  1. what is the best rss feed reader for android
    By wolf1306 in forum Android Apps
    Last Post: 06-19-2011, 03:16 AM
  2. Replies: 5
    Last Post: 12-16-2010, 03:38 PM
  3. What's the best course of action for greater stability?
    By Dan Ang in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 12-04-2010, 12:07 AM
  4. What are the best phone plans available for the google nexus one?
    By CarolClark in forum Google / HTC Nexus One
    Last Post: 09-03-2010, 09:19 AM
  5. What is the best video chat software for the Evo 4G?
    By maxdrive10 in forum HTC EVO 4G
    Last Post: 06-11-2010, 06:46 PM
