What's the best MicroSD 32GB Card for Note 2?
Hi all,
I've read a bunch of scattered threads about MicroSD cards but would like to get some opinions on them here.
Mainly I was wondering if the Note 2's 1080p recording capability requires a particular speed memory card? I haven't bought a card in a while and I'm out of the loop on specs these days.
Some people have posted a great buy from Best Buy on a 32GB card - [Only registered and activated users can see links. Click Here To Register...]
But some reviews got me thinking about throughput speed needed to do continuous 1080p recording. Someone was saying this card has ups and downs as far as speed. And then Joe The Insider mentioned Samsung cards being more consistent.
Maybe someone can school me on the specs I should be looking for in a 32GB card for the Note 2.
If it's not a big deal, I'll just get the one from Best Buy.
Thanks all!! And Happy Thanksgiving!
Re: What's the best MicroSD 32GB Card for Note 2?
Quote:
Hi all,
The Class 10 card is about the best you can get, as far as I know. Some have said the Class 10 is overkill for smart phones but there really isn't a big price difference between the Class 10 and Class 6. I have the SanDisk 64GB Class 10 and it's good for me.
I say if you can snag one, get that puppy. :D
I would agree, for the price difference between a 32GB and 64GB card you might want to consider the 64GB class 10, I got mine from amazon.com for under $60. Crazy how cheap they are now compared to a year or so back and what we all paid then.
I don't know how reliable Joe's info would be on that aspect. In another thread he ordered an sd card instead of micro sd.
The Nottinator
Go to Amazon and get the 64GB micro-SD for $38 now! [Only registered and activated users can see links. Click Here To Register...]
This is the price of the "lightning deal" but apparently they lowered the regular price to it too. Not sure how long it will last.
The Nottinator
I copied the wrong link, i know the difference bet ween the 2.
Sent from my SCH-I535 using Android Central Forums
Yep, picked up another one.
Ok, it happens.
The Nottinator
Thanks all!! I ended up getting the 32GB sandisk for $17.99.
I thought about the 64GB but its another 20 bucks and I have already overspent on my other accessories!!
Plus, on my DROID X I only have 16GB and have never maxed it out (not a heavy gamer or mp3 person )!
Sent from my DROIDX using Tapatalk 2
Is it better to have a 16g phone and a 32g card or a 32g phone and a 16g card? Are they the same? I guess what I am asking is this: If I move a game (or other app) to the sd card, does it run at the same speed when I use it as if it were on the phone? Does moving things to the sd card free up space on the phone and help it run faster? Are there some things that should be stored to the sd card, but not others? This has always bugged me not knowing...
You can't store apps on the SD Card. Photos, music, movies, etc on your SD Card. All the apps are stored on the internal memory.
- - - Updated - - -
Good deal!!
With rooting there is a work around that will let you make the SDCard the primary storage, but I'm not sure I am going to go that route. Also I thought the add on data for games still goes to the storage card, is that not the case? Its hard to keep it all straight sometimes with so many threads and sites to read.
U had the the thunderbolt. Cane with a 32gig. have the rezound using the same card. Will on the note2 as well
sent from either my HTC Rezound or my Samsung Galaxy 10.1 tablet
Is there a difference between this card and the "Mobile" version? On the Sandisk site, it looks like the "Mobile" version includes a "Memory Zone" app for Android that simplifies file management.
Question : Is there a program that will read what type of SD card is installed ? Like CPUID ?
