Results 1 to 9 of 9
- 11-29-2012, 02:14 PM
Thread Author #1
bluetooth car pairing problem
2010 VW GTI. Has always paired no problem with all other previous phones. Doesn't discover the N2 for some reason though. Would bluetooth 4 have anything to do with that? I can't think so - should be backwards compatible with whatever the car has. Then again, we are talking about VW und technik Deutsche which can suck based on personal previous experience with anything built in Wolfsburg
I won't bore you with the radio that locked itself out randomly or alarm systems that armed themselves and then went off while driving down the interstate........
- 11-29-2012, 02:20 PM #2
Re: bluetooth car pairing problem
Well FWIW I sell Acuras and I had a client who couldn't get their car to import their contacts from a GS3. Our cars don't usually have that problem. Idk if they're related issues though.
Sent from my DROIDX (sold my GNex to buy the Galaxy Note II) - 11-29-2012, 10:48 PM #3
- 11-29-2012, 10:59 PM #4
- 11-30-2012, 06:48 AM #5
My Camry works fine but forget using blue tooth if you connect using blue tooth if you connect via a audio cable for media.
- 11-30-2012, 07:09 AM
Thread Author #6
- 11-30-2012, 08:25 AM #7
- 11-30-2012, 09:12 AM
Thread Author #8
Operator error (i.e. big DUH on my part
). Fire up bluetooth, then make sure you CHECK the box that says something like "you want your device to be visible to everything in the universe" - aka discoverable, then click scan. If you don't check the box, the very fine print (thanks Google) notifies you that "this device will only be visible to other paired devices". It's early in the morning, I'm working on my first cup of coffee - guess I'm entitled to the occasional brain fart huh?
- 01-22-2013, 08:49 AM #9
Workaround 4.0.4 auto bluetooth pair problem
By DJ41 in forum General Help and How ToReplies: 6Last Post: 04-08-2013, 01:37 AM -
Photon Bluetooth Car Connection Problem Confirmed At Sprint Store
By rinkeedink in forum Sprint PhotonReplies: 11Last Post: 08-09-2011, 07:11 AM -
Bluetooth Car Connection Problems: Dodge Journey
By rinkeedink in forum Sprint PhotonReplies: 0Last Post: 08-01-2011, 10:31 PM -
Bluetooth phone pairing problems
By Tricoder in forum ASUS EeePad TransformerReplies: 3Last Post: 07-12-2011, 02:52 PM -
pairing problem w/ Plantronics Discovery 975
By gehx in forum Motorola DroidReplies: 4Last Post: 05-04-2010, 12:42 AM
Reply
