Results 1 to 21 of 21
Like Tree1Likes
  • 1 Post By DroidXcon
    pjfan9110's Avatar
    Posts
    Global Posts
    13 Global Posts
    Default Micro USB charger loose
    Hi all,
    My fiance and I got our Note 2's. the micro usb charger seems really loose and falls out really easily. just wondering if others have the same "issue" or if this is just common? thanks for the advice/help.
    pjfan9110
  2. #2
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Default Re: Micro USB charger loose
    Mine is super firm ... are you using the white one that came with the phone or an old one?
    If i've made life easier buy me a Macchiato
    pjfan9110's Avatar
    Posts
    Global Posts
    13 Global Posts
    i'm using the one that came with the phone...i bought a different micro usb cable for my car, and it's the same thing...
  4. #4
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    if its loose to the point where it could fall out i would go to verizon and ask for a replacement
    collett likes this.
  5. #5
    Yeah definitely should snap tight into place. No idea why it would be loose straight out of the box. Both are like that or just one?
    Samsung Galaxy Note 2 on Verizon
    Jelly Beans Build 16 - Perseus 36.3
    pjfan9110's Avatar
    Posts
    Global Posts
    13 Global Posts
    Quote Originally Posted by DroidXcon View Post
    okay, thanks for the help...
  7. #7
    mine is really firm, return it for a new one.
    Sent from my SCH-I605 using Android Central Forums
  8. #8
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Quote Originally Posted by pjfan9110 View Post
    let us know how it went, when you pay $299+ for a phone it better be in perfect shape.
  9. #9
    mine is loose out the box also.
  10. Thread Author  Thread Author    #10
    pjfan9110's Avatar
    Posts
    Global Posts
    13 Global Posts
    i took both phones to verizon last weekend, and they basically told me it was normal. i asked if i could see another note 2 and charging cable to kind of compare, and the rep said no. i asked if i could just see a cable, and they said no. he said that all the note 2's are like that and there was nothing they could do. oh well, i'll just live with it...
  11. #11
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Oh that's some BS. . It could be your cable one of my cables are very loose in my note but all the others are right and snug. go to a different store or call CS if its not your cable
    From my Galaxy Note 2 via Tapatalk
  12. #12
    NHBass39's Avatar
    Posts
    ROM
    Stock rom/rooted
    I wouldn't settle for that answer. See a manager or call Verizon.
    Sent from my ADR6425LVW using Android Central Forums
  13. #13
    It is not normal mine is very tight. You should absolutely get that replaced immediately!
  14. #14
    I noticed the tips on the charge cable are shorter than other cables that I have. Mine seems tight but my son's cable to his Note 2 is loose and keeps falling out. My opinion is the tips on the cable is the problem.
    Update: My son tried my Note II cable in his and it is tight. Our GS3 cable are tight also. So in his case it is the cable that makes it loose.
    Still by looking at our Note II cable ends compared to our GS3's, they are shorter on the Note II.
  15. #15
    Idk how it feels for you so I can't honestly say what it is. I will say that when I first got the phone and considered the bezel's effect on the port I was a bit concerned, but once I plugged it in, it was a solid connection with a decisive stop and no wiggle. Nothing at all feels even slightly lose. Don't settle. It won't get better! Throw up a pic of your connector maybe they are different.
  16. #16
    I have the same problem!!!
    Its so annoying! ! The cable is short and falling out so easily
  17. #17
    Hi. I received my Note II yesterday. I too thought my phones connector was loose. However once i used a different micro usb cable the connector fit pretty snug and was actually hard to plug out. So in short it is a problem with the micro usb cable provided with the phone.
    Edit: Oh sorry did not notice your post.
    Quote Originally Posted by leroybrute View Post
  18. #18
    Quote Originally Posted by Billy Pop View Post
    Here is a good replacement cable. It is from Belkin so the quality should be outstanding.
  19. #19
    I thought I was the only one with a loose phone....better tighten up that chastity belt. Nah...but in all honesty my cable doesnt stay in either...it actually slides right out as soon as I stick it in (my dirty dirty mind). I guess I will try another cable to see if it fits.
  20. #20
    PiN2WiN's Avatar
    Posts
    Global Posts
    3 Global Posts
    Hey, so what was the verdict on all of this? I tested this loose microusb wire, or loose microusb port (not sure which is the problem) with 4 note II's. Of the 4, 2 of the devices had the problem right out of the box. I tested both devices with the microusb wire that came with it, and both of them were loose and eventually fell out. I tested the two devices with another samsung oem wire, and it was more snug (still not to my satisfaction though). After troubleshooting, I came to the conclusion that it must be the wire. However, here is what made me completely UNCERTAIN, and oh so ever CONFUSED: I have a samsung multimedia dock which connects the note ii to my TV by plugging in the note ii into the dock via microusb. After I tested all four devices, the same 2 devices that I had problems for with the loose microusb wire, would produce flickering on my tv display! This should be an indication of a faulty microusb port (the other devices did not produce flickering on my tv display, and these were the devices that I DIDNT have a problem for the loose usb wire). Now I am extremely confused as to what the exact problem is, the microusb port or the microusb wire. I am sorry that you had to go through having a weird device or wire, and would love to hear if you ever came to a resolution with this matter.
    tx in adv
  21. #21
    Jerry-O's Avatar
    Posts
    Global Posts
    280 Global Posts
    I had the exact same problem with the cable that came with my note 2. I swapped the cable for the one I got with my GS2 and the problem was gone. I wonder if there was a bad batch of cables.
    Sent from my SCH-I605 using Tapatalk 2
  1. Replies: 0
    Last Post: 11-24-2012, 06:58 AM
  2. Droid 2 Batter and Micro USB charger
    By cheeseman057 in forum Motorola Droid 2
    Last Post: 08-25-2012, 03:13 PM
  3. Micro USB coming loose!
    By Jamezcua in forum Verizon Droid Incredible 2
    Last Post: 07-25-2011, 06:17 PM
  4. Wtb: Rocketfish micro usb charger with serial code rf-mcb90
    By Matty Mo in forum Sold / Archived Marketplace Threads
    Last Post: 02-10-2011, 11:42 PM
  5. Does the Evo use a Micro USB charger?
    By kenmid EVO in forum HTC EVO 4G
    Last Post: 05-29-2010, 11:53 AM
