Results 1 to 22 of 22
- 12-03-2012, 01:54 AM
Thread Author #1
A way for Home button to turn on screen but not go home?
On my gs3 when the screen is off and I press the home button it turns on the screen but stays in the app I was in when it went to sleep. On the note 2 it turns it on AND goes to the home screen. Any way to change this behavior?
Sent from my SCH-I605 using Tapatalk 2 - 12-03-2012, 06:31 AM #2
Re: A way for Home button to turn on screen but not go home?
- 12-03-2012, 06:45 AM #3
- 12-03-2012, 06:49 AM #4
- 12-03-2012, 06:51 AM #5
- 12-03-2012, 11:10 AM
Thread Author #6
Thanks guys! It appears to be linked to a setting in Nova launcher. Weird. Had the same launcher on my gs3
Sent from my SCH-I605 using Tapatalk 2 - 12-03-2012, 11:19 AM #7Galaxy Note II - Rooted - Black Status Bar w/WiFi Toggle
- 12-03-2012, 11:30 AM
Thread Author #8
- 12-03-2012, 11:43 AM
Thread Author #9
Now I'm even more confused. If I make the home button perform an action in nova it will turn the phone on and perform the action all with one press. I turned of nova and its happening in TW too. If I turn on a lock screen it will leave me where I was if after I unlock but I don't want a lock screen. Are you guys using lock screens?
Sent from my SCH-I605 using Tapatalk 2 - 12-03-2012, 11:54 AM #10Galaxy Note II - Rooted - Black Status Bar w/WiFi Toggle
- 12-03-2012, 12:46 PM #11
- 12-03-2012, 01:07 PM
Thread Author #12
It seems to be happening as part of the lock screen settings. Can someone turn off their lockscreen and and see if when you press the home button (((when the screen is off))) if it takes you away from whatever you were doing and takes you to the home screen? Thanks!
Sent from my SCH-I605 using Tapatalk 2 - 12-03-2012, 01:44 PM #13
Galaxy Note II - Rooted - Black Status Bar w/WiFi Toggle - 12-03-2012, 01:45 PM #14
- 12-03-2012, 02:08 PM
Thread Author #15
- 12-06-2012, 11:31 AM #16
Same problem here. Driving me crazy. I've tried every combination I can think of to get my phone to do what it used to do before JB. I use my phone in my car a lot so I dont use a lock screen. However, the other times I'm not in my car and the screen times out when I am reading an article or something and I press the home button it wakes the screen up and goes back to home screen. If I unlink the "default action" in nova prime, it will not let my home button take me to the home page when on other tabs. Frustrating. I wish there was an easy fix to this. I mean I have had 4-5 droids and never had a problem with this when I just used "no lock".
- 12-06-2012, 12:04 PM #17
Galaxy Note II - Rooted - Black Status Bar w/WiFi Toggle - 12-06-2012, 12:35 PM #18
- 12-06-2012, 12:46 PM #19
So I think that I have found the solution to the problem thanks to insane42 and his advice in the thread linked below. My problem was I had S-voice disabled, because it doesn't work very well at all for me.
I turned it back on and checked the "open via the home key" under apps>s voice>settings...you can then change the default actions via whatever launcher you want and should work fine. Mine now does with with nova prime. good luck .
Using home button to "wake up" with Jellybean - 12-06-2012, 05:21 PM #20
- 01-04-2013, 05:23 AM #21
Thanks folks! I never thought to see if this was fixable and just assumed it was JB. Re enabled S Voice and Samsung TTS and back to screen toggle again. I was getting tired of reaching for the power button. I have it wirelessly charging beside me in the living room (Touchstone lives! Palm RIP) and it's much more convenient to just tap the home key and resume whatever I was doing.
- 03-20-2013, 10:58 AM #22
Normal time you have to hold down power button to turn on?? Please help!
By bcnpesa in forum Google Nexus 7 TabletReplies: 13Last Post: 02-14-2013, 12:42 AM -
How to set volume buttons to turn on screen?
By pedromsouza in forum AT&T ATRIXReplies: 7Last Post: 06-14-2012, 01:52 PM -
Hard to turn on & screen randomly flashes??
By usmc176 in forum ASUS EeePad TransformerReplies: 0Last Post: 05-25-2011, 11:54 PM -
Where are the buttons to turn on/off the Wifi, Bluetooth, 4G, etc?
By Kristy_Joy in forum HTC EVO 4GReplies: 5Last Post: 07-12-2010, 07:37 PM -
Display last app when turning on screen instead of home? EVO
By architectjon in forum General Help and How ToReplies: 8Last Post: 06-24-2010, 08:27 PM
Reply
