Wireless Tethering on the Verizon Note 2
raffitou
47
OK, so now I'm rooted using the root method at XDA at the link:
[GUIDE][VZW Edition]How to Root the VZW Galaxy Note II and more! - xda-developers
Phone works perfectly without a hiccup or loss of responsiveness.
Very appreciative of their work!
"First and formost all credit goes to MrRobinson and Beanstown101!!" and to Droidstyle for putting it together!
Now I need a way to get Wireless Tethering up and running. Anyone with any success?
I did come across a link by Droidxcon "Try this http://forum.xda-developers.com/show....php?t=1988735
[App-Mod/Source] WifiTether for JB TouchWiz Roms"
I tried it but couldn't get it to work. Not sure if it's me or the software isn't compatible?
Has anyone been able to achieve wireless tethering?
If so how? Instructions with links to any app to download would be most appreciated.
Thanks
DroidXcon
11,102
3,392
There are some settings that you may need to change, let me see if i can find the example i saw and ill get back to you.
DroidXcon
11,102
3,392
This:
I used the WifiTether-TrevE_Mod_11_22_2012_driverReload2
My settings:
Device Profile: Generic ICS/JB (wlan0)
Setup Method: Netd-NDC (master)
Send Netd Max Client Cmd - Checked
Wifi-driver reload 2 - Checked
Routing fix - Checked"
From my Galaxy Note 2 via Tapatalk
Tari
113
This:
My settings:
Was wondering about this, myself. The above works, thanks. :)
cj100570
Spoken Word?
Nov 12, 2009
417
24
Thanks
Shoot me a PM. I have the cure for your tethering ills.
BlakeDC
Active member
Jul 14, 2010
33
This:
My settings:
Works! Like a bawse!!
juicem2
19
I updated to the newest version possible on wireless tether (3.3 pre 2 under about) used galaxy s3 as device checked wifi driver reload 1 and 2, setup method netd-ndc (master), checked send netd msz client, and checked routing fix. Tethering works perfectly on my Verizon Galaxy Note 2!!!!
Bond32
1,358
35
You can also use a widget like fattin hotspot toggle , it bypasses the check for hotspot. No root needed. Same thing was on the s3
Sent from my SCH-I605 using Tapatalk 2
karsdroid
1,058
5
I'm a fan of foxfi also....i'm more than willing to pay for the app cux it works great, i like having the choice to set a password no one can jack my data connection :)
karsdroid
1,058
5
Thank I'll check out the paid version.
It's about $7 for the app.....i'm a fan of supporting developers who come up with great apps that i use often!! this one is very stable and i've never had a problem using it. the free version does time out so if you are just jumping on quickly to problem....its also a good way to see if its working for you before committing to buy.
VolMan37421
76
I've been using FoxFi on my Droid Razr. Glad to hear it works with the Note 2. Nine days and counting till the Christmas bonus arrives and then, so does the Note 2!
szcad
