Is there a way to change where screen shots and photo editor images are stored? I tend to share a lot of screen shots and they automatically save to the internal memory and not the sd.
Thanks
Sent from my Verizon Note Duece
Printable View
Thanks
Goto the file manager settings for gallery should be able to set which folders save where.
Sent from my SCH-I605 using Android Central Forums
I always set my pics to store on the ext. SD card. with the camera, just checked the gallery app and it doesn't have a setting for where to save images.
My pictures are saving on the sd card just fine but I can't figure out a way to save screen shots to the sd card without manually transferring them
I have not found a way yet either. Still playing around, but maybe a creative dev can put together a mod for us?
