1. dedduck0121's Avatar
    Picked up my note 2 yesterday and can't figure out how to add a wifi button to my notification bar. Can I do this without rooting? Wifi button questions - Note 2-uploadfromtaptalk1354710139363.jpg
    Sent from my SCH-I605 using Tapatalk 2
    12-05-2012 06:22 AM
  2. MrMLK's Avatar
    You can't using the stock system. There are a bunch that will add this below that line. I use Wigetsoid.
    12-05-2012 06:52 AM
  3. pool_shark's Avatar
    The wifi toggle was removed in favor of the persistent notification.
    I don't care much for the pull-down toggles, I didn't even use them when I used custom ROMs. Since the power widget isn't on the Note2, I use widget solid. It allows me to use the wifi toggle widget in place of the power widget.
    12-05-2012 06:54 AM
  4. dedduck0121's Avatar
    Kind of what I thought. I will try them out
    12-05-2012 07:03 AM
  1. wifi issues & Questions (DINC)
    By DikaiaKnight in forum General Help and How To
    Last Post: 08-07-2010, 07:56 AM
  2. Tethering and The Barncle Wifi Tethering question
    By thataznguy#AC in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 08-03-2010, 07:01 PM
  3. EVO 4G Wifi Range Question
    By gabato in forum HTC EVO 4G
    Last Post: 04-24-2010, 10:09 AM
  4. WiFi speed question.
    By Semantics in forum HTC Hero
    Last Post: 12-02-2009, 01:29 PM
  5. Camera Button Question
    By mimzy in forum Motorola Droid
    Last Post: 11-12-2009, 12:38 AM
