Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Like Tree2Likes
    mebobio's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Bluetooth issues
    I am having a problem with bluetooth earpieces on the Verizon note 2. I had the Motorola elite silver, ,when used with the note 2, there was a lot of noise and echoed really bad. Went back to the Verizon store and they tried 3 other Motorola headsets, all having the same issue. Tried the Blueant Q2, ,andthe noise was not there any longer. But found out that when the bluetooth earpiece is turned on, cannot use the voice to text on the phone . The second that I shut off the earpiece, the voice to text starts working again. I don't know if this is a phone issue, ,or jellybean, samsung, ,but it is getting really annoying. Any suggestions? ??
    Thanks
  2. #2
    karsdroid's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Bluetooth issues
    Quote Originally Posted by mebobio View Post
    Thanks
    I use the LG around the neck bluetooth headphones and they work great. sound quality great and the pairing was smooth as silk....try connecting a different bluetooth headset and see if same issue to narrow down if its the phone or if its the headset.
  3. #3
    Markster1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm using a Plantronics 903+ with no issues so I would say it's the bluetooth devices.
    Sent from my Verizon Note 2, finally!
    mebobio's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the input, ,when I went back to Verizon, they tried 2 different Motorola elite silver earpieces , and 2 other Motorola brand earpieces, and I had 2 jawbone icon earpieces, and all of these was really noisy and echoed bad. However, I did not have the chance to test the voice to text issue with these. (Didn't know of the issue at the time. ) I will try others, but just not sure if it is a bluetooth issue with the phone, ,other. .......thanks again
    mebobio's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ok, I just tried the jawbone icon earpiece, and it does the same thing. With the earpiece turned on, and I go to text message, and bring up the microphone, it just stays blacked out and will not work. Turn off bluetooth earpiece, works fine. Could there be some sort of setting somewhere that could cause this?
    mebobio's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    To update, I went into the bluetooth settings, ,there are 2 settings, CALL AUDIO, AND MEDIA AUDIO. When I shut off the media audio, the mic will work with the bluetooth earpiece still on. Is this normal, or should we be able to do both. Any ideas? ?
  7. #7
    Markster1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Should be able to do both. Media is like streaming music. If that device doesn't do music (a2dp) turn it off.
  8. Thread Author  Thread Author    #8
    mebobio's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Both are A2DP and I can hear thru them, music, incoming caller id, maps navigation and so on. But with the media audio checked, the mic doesn't work. And ideas as to what to do to get it to work?
  9. #9
    Markster1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't know. I just double checked mine while listening to music and it transcribed my voice just fine.
  10. #10
    Markster1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You using swype or stock keyboard?
  11. Thread Author  Thread Author    #11
    mebobio's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Stock keyboard, also does it with swiftkey 3....
  12. #12
    Markster1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've been thru the settings and don't see anything that could be blocking this. Maybe someone else knows a fix, I'm at a loss.
  13. Thread Author  Thread Author    #13
    mebobio's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just figured out that issue with the speak to text part of it. Funny, the default app had a language update (US English). I did the update and now it's working. [Weird] Now to figure out the noise and echo issue, and I'll be all set......lol...
  14. #14
    Markster1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Good luck
  15. Thread Author  Thread Author    #15
    mebobio's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for all your help. .....
  16. Thread Author  Thread Author    #16
    mebobio's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ok, so after over night, the problem returned. Called Verizon and they replaced the phone. I didn't think that that would fix the problem. On startup it worked fine. So I loaded up my apps, ,updates from the play market, and found that when I updated google search to the latest update, (2.2.9.542574) the problem would return. Went to manage apps, deleted update back to working fine.
    What do you think?
  17. #17
    pcbtmr's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have (2) Jawbone Icons, both paired with the Note2 initially and are listed in the paired devices. Neither will re-connect, even manually tapping the device does not re-connect. I noticed that unparing them then manually selecting it to pair does reconnect. What a pain!
  18. #18
    corki2's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have the same problem. When my bluetooth headset is on, the voice to text on my keyboard doesn't work. I turned off media in the bluetooth setting and it works. So I don't think it's your device. Seems to be a glitch with the OS. I don't listen to music through my bluetooth anyway, so it's not a problem for me, but they need to fix it.
    Sent from my GT-P3113 using Tapatalk 2
  19. #19
    Markster1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well it works fine for me so I think the bluetooth devices don't have something the phone needs from it.
    Sent from my SCH-I605 using Tapatalk 2
  20. #20
    corki2's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just tested my Command one, Blue Parrot B250-Xt+ and my Plantronics. M155 all with the same results. They all have to have media unchecked in order to use the voice reply on SwiftKey Flow Beta and the stock keyboard. I wonder if there is another setting somewhere. What model bluetooth is this working with?
  21. #21
    Markster1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by corki2 View Post
    Plantronics 903 Plus
    corki2 likes this.
  22. #22
    corki2's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This happens I messaging when I try to voice reply. It works fine everywhere else.
  23. #23
    Markster1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yep, in text messaging I can do a voice text on my bluetooth device no problem.
    corki2 likes this.
  24. #24
    corki2's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well, I've done some research and it seems a few people are having the same issue . I have no idea why it happens to some and not to others. My workaround is to engage S-Voice by tapping my headset and ask it to ready my text message. After it reads it, you get a popup asking if you want to reply. Al you have to do is tap that and it will let you reply and send it with your voice. I'm sure someone will figure out why it isn't working fro some people eventually.
  25. #25
    Markster1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    There have been some other people having a separate issue and found out it was linked to "two step" authentication of their Google account. I'm wondering if somehow this is all somehow related.
  1. Evo bluetooth issue
    By robh2 in forum HTC EVO 4G
    Last Post: 07-01-2010, 05:49 PM
  2. Droid Incredible Bluetooth Issue - Bug?
    By bam1122 in forum Verizon Droid Incredible
    Last Post: 05-14-2010, 09:17 PM
  3. Bluetooth Issues
    By Dunc in forum Google / HTC Nexus One
    Last Post: 03-17-2010, 04:22 PM
  4. Bluetooth issues
    By soulfulzeta in forum HTC Hero
    Last Post: 12-22-2009, 02:56 AM
  5. bluetooth issues with jabra bt8040
    By rsbenedict in forum HTC Hero
    Last Post: 11-07-2009, 06:10 PM
