1. Benny Morrison's Avatar
    Anyone else not having the settings in the stock calendar or the Samsung calendar apps stick when you change them? I change the notification ringtone for both and turn off the 'Turn the screen on for new notifications' setting on the Samsung calendar and when the phone is restarted, those settings revert to what they were when I got the phone. Very annoying and having the screen come on for all of my meeting notifications is NOT what I want - it meant the screen was on for 6.5 hours that first day.
    Anyone else seeing this at all?
    Thanks.
    12-07-2012 08:58 AM
  2. bacchusmarsh's Avatar
    Yes I have this same problem and it annoys me.
    Did you ever find a solution?
    04-13-2013 09:53 PM
  3. nlitenme's Avatar
    I had the same problem & ended up disabling the app that I DIDN'T want to use (in my case, Samsung calendar), now I don't have the problem. It seems like similar apps fight with each other with the settings.
    04-14-2013 02:20 PM
  4. bacchusmarsh's Avatar
    Thanks, I removed google calendar (and the setings stuck) as, although i like it and use it on my laptop browser too, I prefer the fuctionality of s planner on the Note 2 (being able to move and re-size events with out manually changing date and time).
    Only problem is now i get a sync error and cannot get my s planner to sync to my google calendar online. AAAHHH!
    If only google calendar app had same functionality of the desktop/browser version.
    04-14-2013 06:21 PM
  5. nlitenme's Avatar
    I agree completely!
    04-14-2013 06:51 PM
  6. bacchusmarsh's Avatar
    Ok I have a solution!
    Removed google calendar app and removed my google account from the phone (note 2), then re-added my google account, clear data of s- planner (not sure if this was necessary) and restart phone.
    The s - planner settings stick and I have sync with my google account/calendar... finally.
    04-15-2013 12:05 AM
  7. kentman's Avatar
    I had to diable both the Samsung Calendar and the Samsung Calendar Widget. After that, my Google Calendar settings stick. Cool.
    04-15-2013 10:02 AM
  8. grumpyjoe's Avatar
    This is why i use "Business Calendar". So much better.
    Sent from my SCH-I605 using Android Central Forums
    04-16-2013 05:52 AM
  9. kentman's Avatar
    Stock Google for everything as much as possible. Once I am ready for upgrade, I will be rocking AOSP on my Note 2.
    04-16-2013 12:38 PM
  10. arundc's Avatar
    How do you disable the Samsung Calendar? I get two reminders for the same events now...other being from the Google Calendar app. Thanks.
    04-16-2013 01:20 PM
  11. nlitenme's Avatar
    Go into Settings > Application Manager > swipe until All apps are showing > find & tap on Calendar (make sure it's your Samsung one) > choose Disable
    04-16-2013 01:49 PM
  12. arundc's Avatar
    Thank you, it worked! FINALLY :-)
    nlitenme likes this.
    04-17-2013 09:47 AM
  13. nlitenme's Avatar
    No problem, enjoy!
    04-17-2013 10:36 AM
  1. Replies: 11
    Last Post: 12-01-2012, 09:44 AM
  2. One thing I've noticed on the Note II
    By OceanView in forum Samsung Galaxy Note 2
    Last Post: 11-23-2012, 07:36 PM
  3. Anyone planning to buy the Note II for full price?
    By Sh3ngLong in forum Samsung Galaxy Note 2
    Last Post: 10-24-2012, 10:10 PM
  4. one issue with razr maxx
    By ttens in forum Droid RAZR MAXX
    Last Post: 06-10-2012, 11:15 PM
  5. Love the Droid X, but the Iphone camera owns the Droids
    By Thadeus50 in forum Motorola Droid X
    Last Post: 07-22-2010, 04:42 PM
