Results 1 to 7 of 7
Like Tree1Likes
  • 2 Post By scorpiodsu
  • 1 Post By Coug
    jodyberry's Avatar
    Posts
    Global Posts
    381 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default How to get more than 1 page in S-Note?
    Sorry if this has been asked before, but I couldn't find it thru Google.
    If I'm making a list in S-note, how would I extend the current page or make another in that same file?
    In one of LucidMike78's videos, he has a button at the bottom that can do it. But I think he has the International version.
    Thanks all...
  2. #2
    scorpiodsu's Avatar
    Posts
    Global Posts
    5,147 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: How to get more than 1 page in S-Note?
    At the bottom of the page in s note there should be a + sign. Hit that to add a page and you should get a pop up asking what type of page. And then after you select it should become 2/2 and so on.
    Sent from my SCH-I605 using Android Central Forums
    Coug and jodyberry like this.
  3. #3
    Coug's Avatar
    Posts
    Global Posts
    40 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    +1. something else, when you want to export I use pdf instead of jpeg. pdf creates one file with multiple pages, while jpg creates a separate file for each page.
    Quote Originally Posted by scorpiodsu View Post
    jodyberry likes this.
  4. #4
    karsdroid's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    you can't add a page through the "pop up" note, the one that pops up when you take out the pen. you need to hit the arrow in the top left corner which will take the pop up app into the full app. then you will see the symbol at the bottom with a plus that adds a page....
    jodyberry's Avatar
    Posts
    Global Posts
    381 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Duh, so simple and I missed it!! Thanks a bunch!!
  6. #6
    scorpiodsu's Avatar
    Posts
    Global Posts
    5,147 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I think you're misunderstanding. After you get the + plus sign a pop up menu comes and asks what type of page you want to add. S pen is not needed at all for this.
  7. #7
    scorpiodsu's Avatar
    Posts
    Global Posts
    5,147 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jodyberry View Post
    No problem.
  1. How to get more _internal_ memory
    By dmullens in forum AT&T LG Phoenix/Thrive
    Last Post: 07-06-2013, 09:36 PM
  2. Replies: 5
    Last Post: 12-05-2012, 05:15 PM
  3. How to get rid of the '+' in my contacts phone #
    By boyer61 in forum Verizon HTC Thunderbolt
    Last Post: 11-03-2011, 10:53 AM
  4. how to get ST sim working in a inspire
    By bmxjason in forum General Help and How To
    Last Post: 09-10-2011, 12:47 AM
  5. [How To] Get rid of ads in Notification bar
    By koopakid08 in forum General Help and How To
    Last Post: 07-11-2011, 04:42 PM
