Results 1 to 2 of 2
    Default Odd Contacts Problem
    I'm having a strange issue with my Note 2. I keep all my contacts in Google. None on the phone, none on the SIM. However, when I look through my contacts, there are numerous ones missing. I have to go into the contacts settings, select Contacts to Display, then Customize List for them all to show up. Once I do this, they'll show for a while, but be gone again later in the day and I have to do it all over again. If I select 'Show All', they don't all show up. They only all show if I select Customize List.
    Any idea why it does this? Is there a way to make the Customize List permanent? I've looked but can't find anything.
    Any help will be greatly appreciated. This is really the only problem I've had with this phone. I love it otherwise.
  2. #2
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Default Re: Odd Contacts Problem
    Quote Originally Posted by Kaizmuth View Post
    I would log onto your gmail and see how you have them organized,,,or you can just shut off the Sync option for your gmail account, sounds like everytime it reSyncs it changes the way you have it set up
    If i've made life easier buy me a Macchiato
  1. odd charging problem....
    By ctmaineah in forum HTC EVO 4G
    Last Post: 06-09-2010, 02:45 AM
  2. ICE contact problem
    By azjerry in forum General Help and How To
    Last Post: 04-05-2010, 11:18 AM
  3. Contact Problems
    By mannyvigi1985 in forum HTC Hero
    Last Post: 03-19-2010, 03:49 PM
  4. Contacts problem
    By Macklesdaddy in forum Google / HTC Nexus One
    Last Post: 01-25-2010, 11:37 AM
  5. Anyone run into this contacts problem?
    By Cirro in forum Motorola Droid
    Last Post: 01-16-2010, 06:38 AM
