Results 1 to 9 of 9
    NHBass39's Avatar
    Posts
    Carrier
    Stock rom/rooted
    Default Need help adding the WIFI button on the top. (Yes I'm rooted)
    Can someone explain to me how to get it there. I see it over on XDA, but I need it in newbie terms LOL.
  2. Thread Author  Thread Author    #2
    NHBass39's Avatar
    Posts
    Carrier
    Stock rom/rooted
    Default Re: Need help adding the WIFI button on the top. (Yes I'm rooted)
    Can this be done with root explorer? Deleting the file and add the one at XDA?
  3. #3
    ibcop's Avatar
    Posts
    Global Posts
    6,064 Global Posts
    Carrier
    Stock
    I'm sure someone will help ya out....but I'm in left field here.
  4. #4
    Just follow the instructions on xda, it's really easy. With root Explorer you can extract the zip, copy the file, and paste it to the specified location. Say yes when prompted to overwrite, restart, and that's it.
    NHBass39's Avatar
    Posts
    Carrier
    Stock rom/rooted
    So I just paste it in the system apps and overwrite? Correct?
    Sent from my SCH-I605 using Android Central Forums
  6. #6
    I use widget solid to replace the old power widget, including the wifi toggle.
    I've actually found the persistent notification somewhat useful.
    I have a dual-band router and in certain areas of my house I get a better signal with 2.4 instead of 5. The persistent notification makes it easier to switch.
  7. #7
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Carrier
    Stock for now
    Quote Originally Posted by NHBass39 View Post
    Yes
    Then restart
    From my Galaxy Note 2 via Tapatalk
    NHBass39 likes this.
  8. Thread Author  Thread Author    #8
    NHBass39's Avatar
    Posts
    Carrier
    Stock rom/rooted
    Thank you
  9. #9
    Yup, it's that easy
  1. Where is the power button on the S3?
    By NoNoiPhone4me in forum Samsung Galaxy S3
    Last Post: 11-30-2012, 01:10 AM
  2. need help syncing events I enter on the Charge
    By going_green in forum Verizon Droid Charge
    Last Post: 01-23-2012, 02:21 AM
  3. can the search button on the Rezound be disabled?
    By ShaggyKids in forum Verizon HTC Rezound
    Last Post: 01-19-2012, 10:06 PM
  4. Are the 3 buttons on the bottom customizable?
    By kath00 in forum Google / Samsung Galaxy Nexus
    Last Post: 10-20-2011, 06:35 PM
  5. disabling the mute button on the call screen
    By rounsy22 in forum Samsung Moment
    Last Post: 05-13-2010, 09:24 AM
