Need help adding the WIFI button on the top. (Yes I'm rooted)
Can someone explain to me how to get it there. I see it over on XDA, but I need it in newbie terms LOL.
Re: Need help adding the WIFI button on the top. (Yes I'm rooted)
Can this be done with root explorer? Deleting the file and add the one at XDA?
I'm sure someone will help ya out....but I'm in left field here.
Just follow the instructions on xda, it's really easy. With root Explorer you can extract the zip, copy the file, and paste it to the specified location. Say yes when prompted to overwrite, restart, and that's it.
So I just paste it in the system apps and overwrite? Correct?
Sent from my SCH-I605 using Android Central Forums
I use widget solid to replace the old power widget, including the wifi toggle.
I've actually found the persistent notification somewhat useful.
I have a dual-band router and in certain areas of my house I get a better signal with 2.4 instead of 5. The persistent notification makes it easier to switch.
Yes
Then restart
From my Galaxy Note 2 via Tapatalk
Thank you
