Results 1 to 9 of 9
- 12-09-2012, 05:51 PM
Thread Author #1
- 12-09-2012, 06:19 PM
Thread Author #2
- 12-09-2012, 06:23 PM #3
Re: Need help adding the WIFI button on the top. (Yes I'm rooted)
I'm sure someone will help ya out....but I'm in left field here.
- 12-09-2012, 07:12 PM #4
Just follow the instructions on xda, it's really easy. With root Explorer you can extract the zip, copy the file, and paste it to the specified location. Say yes when prompted to overwrite, restart, and that's it.
- 12-09-2012, 07:23 PM
Thread Author #5
- 12-09-2012, 07:31 PM #6
I use widget solid to replace the old power widget, including the wifi toggle.
I've actually found the persistent notification somewhat useful.
I have a dual-band router and in certain areas of my house I get a better signal with 2.4 instead of 5. The persistent notification makes it easier to switch. - 12-09-2012, 09:15 PM #7
- 12-09-2012, 09:24 PM
Thread Author #8
- 12-09-2012, 09:40 PM #9
Where is the power button on the S3?
By NoNoiPhone4me in forum Samsung Galaxy S3Replies: 21Last Post: 11-30-2012, 12:10 AM -
need help syncing events I enter on the Charge
By going_green in forum Verizon Droid ChargeReplies: 6Last Post: 01-23-2012, 01:21 AM -
can the search button on the Rezound be disabled?
By debsdroid in forum Verizon HTC RezoundReplies: 0Last Post: 01-19-2012, 09:06 PM -
Are the 3 buttons on the bottom customizable?
By kath00 in forum Google / Samsung Galaxy NexusReplies: 14Last Post: 10-20-2011, 05:35 PM -
disabling the mute button on the call screen
By rounsy22 in forum Samsung MomentReplies: 11Last Post: 05-13-2010, 08:24 AM
Reply
