1. iluvmynexus's Avatar
    Hi. I just bought my Verizon Note 2 on November 29th. This post is concerning the battery. For the first few days that I had it, the battery would last from 7 am to 9 or 10 pm with over 20% remaining. Now it is getting under 15% by 8 pm. Is there something wrong with my device's battery? Everyday I have been using it under the same conditions with qifi and mobile network both on. Bluetooth and gps are off.
    12-09-2012 07:41 PM
  2. NHBass39's Avatar
    Something is running in the background. You need to go back and start removing apps to figure it out. I had this happen on my HTC rezound before using SMS pro.
    12-09-2012 07:48 PM
  3. iluvmynexus's Avatar
    Okay, so I should go to my applications and close anything taking up an abnormal amount of ram?
    Thanks for the advice
    Sent from my SCH-I605 using Android Central Forums
    12-09-2012 07:58 PM
  4. scorpiodsu's Avatar
    Just find the apps that are constantly syncing and are more drain while using them. Sometimes we use apps to replace native apps and don't realize they could drain battery a lot more than the native version.
    12-09-2012 08:07 PM
  5. iluvmynexus's Avatar
    Oh I see... well I cleared my RAM and stopped any apps that seemed to be draining power, but none if them seemed very battery-consuming. Do you think its possible for this to be an issue with my actual hardware?
    12-09-2012 08:11 PM
  6. TheBigJMoney's Avatar
    It's certainly possible for it to be a hardware issue, but software is the likely culprit. There are some very useful task/program killer apps that are free. You should use them and see if there's maybe a rogue appbor two updating in the background. Also, check your email and social media accounts as some of them may be on a more active update schedule than you'd like.
    12-09-2012 08:15 PM
  7. ecs180's Avatar
    Check your settings under google now and maps and any other app u have that may be constantly fetching data when your not using your phone
    iluvmynexus likes this.
    12-09-2012 08:16 PM
  8. sudbury78's Avatar
    I downloaded beautiful widgets on Thursday and from that point on my battery has been awful. I deleted it last night and today has been somewhat better but certainly not what it was for the first week.
    Currently: 50%
    9 HR 55m on battery
    Screen: 33%
    android system 19%
    android os 14%
    google services 5%
    facebook 4%
    cell standby 4%
    voice calls 4%
    tweetcaster 4%
    device idle 4%
    media server 3%
    Anything out of the ordinary bass?
    12-09-2012 08:16 PM
  9. NHBass39's Avatar
    Nope. Beautiful widgets can be a battery hog.
    12-09-2012 08:20 PM
  10. iluvmynexus's Avatar
    I have used gsam battery to look for a culprit. The highest app after android system and kernel is Chrome with 7% of my battery usage.
    JediJesus95 likes this.
    12-09-2012 08:24 PM
  11. JediJesus95's Avatar
    I always run gsam and I can check pretty quick if my battery starts draining too fast.
    12-09-2012 09:39 PM
  12. scorpiodsu's Avatar
    Just stopping apps may not be enough. You have to find those with frequent sync settings that are usually the default when first installed. And then maps and Google now can be killer by needing to use location services all the time. Apps that sync a lot and use location services are killer and they don't have to be active in your task manager.
    12-09-2012 09:47 PM
  13. burwil's Avatar
    This. It will tell you all you need to know. Which apps are awaking the phone and how many times and for how long. Not to mention battery consumption.
    12-09-2012 09:48 PM
  14. ecs180's Avatar
    what if it tells u its the kernel?
    12-10-2012 09:59 AM
  15. burwil's Avatar
    That i do not know. Wondered it myself.
    Sent from my Galaxy Note 2.
    12-12-2012 03:05 PM
  16. Irvgotti's Avatar
    Sent from my HTC6435LVW using Android Central Forums
    12-12-2012 03:07 PM
  1. Galaxy note battery
    By tstens22 in forum AT&T Galaxy Note
    Last Post: 12-04-2012, 01:03 PM
  2. Galaxy S3 & Galaxy note battery
    By droid83 in forum Samsung Galaxy S3
    Last Post: 05-30-2012, 05:17 PM
  3. Note Battery Replacement
    By badbradd2 in forum AT&T Galaxy Note
    Last Post: 04-14-2012, 01:56 PM
  4. UK Note Battery in US Note Phone?
    By SebastianNap in forum AT&T Galaxy Note
    Last Post: 03-26-2012, 09:43 PM
