Results 1 to 5 of 5
    ylomnstr's Avatar
    Posts
    Global Posts
    109 Global Posts
    Default Battery not fully charging overnight?
    I'm on my 2nd Note 2. (returned the first one after a few days because I dropped it and dinged the corner and I couldn't deal with that).
    The first one I had stopped charging fully overnight after I dropped it. I figured dropping it damaged something so I didn't think much of it. The night that I dropped it, I charged it overnight and when I unplugged it, it was at 90%. The next night I charged it overnight and it was only at 60%. Unplugging it and plugging it back in finished the charging, but I found it odd.
    I've had the replacement phone for a few days now, and last night, I charged it overnight as I do every night, and it was only at 89% this morning. Any ideas? I do use a splitter on my charger so that my wife and I charge our phones on the same charger and I've been doing this since I had the S3 with no issues.
    Just wondering if I have a bad battery or if this is something anyone else has seen? Find it odd that it's happening with 2 different note 2's now.
  2. #2
    gafly's Avatar
    Posts
    Global Posts
    828 Global Posts
    Default Re: Battery not fully charging overnight?
    Don't use a splitter. Use the charger that came in the box and connect it to a wall outlet (not a usb port on a computer) and see if you still have your issues. Most chargers are 1 amp (I believe this is the case with the S3) the charger for the Note II is a 2 amp charger. It makes a difference.
    Thanked by:
    ylomnstr's Avatar
    Posts
    Global Posts
    109 Global Posts
    Quote Originally Posted by gafly View Post
    Thanks. I didn't know that. I'll try and see if it makes a difference.
  4. #4
    MrSmith317's Avatar
    Mr Fix-It
    Posts
    ROM
    Stock Rooted
    Other thing is to check what's running on your phone. If you're somehow using more battery than can be charged, you'd get this slow drip feed. Oh and always use the stock charger when you can(as Gafly suggested)
    “Around here, however, we don't look backwards for very long.
    We keep moving forward, opening up new doors and doing new things,
    because we're curious...and curiosity keeps leading us down new paths.”
    -Walt Disney
  5. #5
    The charger tip on the oem cable is really short compared to any other cable tip I have seen. And if you look, the port is counter sunk because of the curve of the case. If you turn the phone over you can see half of the tip hanging out of the port. We have 2 N2's at home and we see the same charging issues once in a while. You have to be sure it is clipped in good. And if you move the phone to much while plugged in, the end seems to work out. If I use my Nexus 7 or Moto charge cable I have no charge or connection issues.
  1. Battery not fully charging?
    By kevin.slawinski in forum Droid RAZR MAXX
    Last Post: 08-23-2012, 04:12 PM
  2. Not Fully Charging
    By BGood20 in forum HTC EVO Shift 4G
    Last Post: 11-20-2011, 02:08 PM
  3. Battery dock not fully charging batteries
    By dave1812dave in forum Droid Bionic
    Last Post: 09-25-2011, 11:22 AM
  4. Battery not fully charging
    By dablitzkrieg in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 06-24-2011, 06:27 PM
  5. Battery does NOT fully charge
    By MJ in forum Sprint Nexus S 4G
    Last Post: 05-08-2011, 09:44 PM
