Galaxy Note 2 Screen Mode won't change
Dawn1634
I have a problem with my Note 2 that I can't seem to fix. The screen mode was in standard since I got it, but now it has changed (don't know how) to a "negative" screen. I have tried to change it through normal settings, but it will not change back to normal. When I try to change it all of the options are the same. Even the camera and photos previously taken are "negative". Please help, I HATE this!
DroidXcon
11,102
3,392
You mean the colors are inverted?
Try this settings>accessibility>Negative colors
From my Galaxy Note 2 via Tapatalk
Dawn1634
Thank you, didnt even know that was there. Fixed it for me. Now I feel stupid but I don't know how I changed it in the first place.
DroidXcon
11,102
3,392
Glad its fixed. I didn't know it was a feature either. Glad you are fixed up :)
geneviever
I just got my Note 2. 3 days ago and last night my color changed to negative also. I tried everything and was ready to go back to the store, your recommendations worked perfectly. Thank you, thank you, thank you. You deserve your machiato. If you are in the SoCal area, I will happily buy you one. Genevieve
AmberNote2
I had exactly the same problem, so I am very grateful for the advice, however, I am also concerned that this seems to be happening by itself i.e. not a setting I had changed, therefore I wonder is it a fault? :-\
Mayra Elizabeth
I had the same problem today dont know how it changed!? I even called tech support and they didnt know how to fix it. So happy I didnt have to reset since it was the only option they gave me.. Thank You!!!
TimGall
I had the same problem with my Motorola Moto G, out of the blue. The fix suggested worked a treat. My psecdial thanks to the responder who suggested it.
