Gary02468
Encryption also enforces the password on the lock screen. Looking at my settings it looks like the longest I can set the screen timeout for locking is 30 minutes.
Thanks, that's good to know. So even with device encryption, you're able to set a delay before the lock-screen password is required.
It's interesting that your Note 2's delay options only go up to 30 minutes instead of 60 minutes. That's with the stock version of Android, or something customized? International or US Note 2? And do you happen to know if you had the one-hour option before you enabled device encryption?
