1. volsfan0911's Avatar
    Finally got around to switching out my proclip car mount for the Note 2. For those not familar, it's a modular system with one half mounting to the vehicle and the other specifically designed to hold the device. Since I already had the vehicle mount in my GTI, it was just a matter of taking off the iPhone 4 mount and installing the new one (4 screws, 1 cup of coffee). Sorry for the dust, really need to clean in the interior of my beloved ride. I love the Proclip because you can adjust the tension and looseness/tightness of the swivel point. And, at least for a Mk VI Golf/GTI/Jetta (2010+) it mounts up high so the phone is very easy to see. One thing I'll never do again - spend $1,600 on OEM nav when Google Maps does a better job and I already have it on a phone
    MobileMadness002 likes this.
    12-15-2012 10:22 AM
  2. DroidXcon's Avatar
    https://lh4.googleusercontent.com/-I...December152012
    https://lh3.googleusercontent.com/-6...215_104841.jpg
    https://lh6.googleusercontent.com/-b...215_104349.jpg
    Very cool, ima looking and ima liking
    12-15-2012 12:48 PM
  3. PsYcHoNeWb's Avatar
    Really liking the way that looks. Would be awesome for navigation that way!
    I also saw the whiskers on the cat on your background and thought they were scratches lol.
    12-15-2012 04:02 PM
  4. secondandonly's Avatar
    I was thinking about the proclip, no case in the mount ruins it for me though. I ended up getting the X-grip from Ram. Windshield mount isn't ideal, but it holds perfectly through hot and cold and mounts really easily with the x spring mechanism. I can also fit most of my Note 2 cases in the mount.
    I did a review here if anyone hasn't seen the x grip
    12-15-2012 06:35 PM
  5. techgeek32#WN's Avatar
    I am waiting for my ProClip as well. Mine has the built in charger unlike he previous poster that just has the holder. It is a new item. I should get it next week and will take some pictures. I have used my ProClip for my last 4 phones. I would highly recommend it.
    12-15-2012 07:14 PM
  6. bigguy_132's Avatar
    So will this clip work with the flip cover on the phone? I'd like to get something like this but hate to swap covers just to use it.
    12-15-2012 08:00 PM
  7. Eggshen's Avatar
    I bought the Samsung universal car mount and it works perfect with the Note II. It will even hold the phone with the Verizon kickstand case on. Here is a picture. The mount holds the phone very sturdy and you can also adjust this mounts swivel tension. No need to bolt anything.
    12-16-2012 01:46 PM
  8. kilofoxtrot's Avatar
    I am using the Mountek dock... I never use my CD player.
    Zero Hunter and JediJesus95 like this.
    12-16-2012 02:22 PM
  9. Frenzytom's Avatar
    http://ecx.images-amazon.com/images/I/61A7xR3hU-L.jpg
    That is what I have as the CD player is no longer being used. I like the mount but think the CD/swivel angle is not ideal but useable, even at its max angle.
    12-17-2012 09:35 AM
  10. volsfan0911's Avatar
    Sorry I didn't answer earlier. I don't think so - right now, it's advertised as "no case" and it's pretty tight sliding into the retention grooves. Anything that added thickness to the phone probably isn't going to work. Ram X might work better with the flip cover installed.
    01-07-2013 11:59 AM
  11. Zero Hunter's Avatar
    This is what I have too. Very ingenious idea since a lot of people don't really use CDs as much as before. It's pretty sturdy too.
    01-07-2013 02:49 PM
  12. kgk1985's Avatar
    I got a Note 2 specific clip in Mount on ebay for $8. Was skeptical ordering something cheap from China, but the phone fits perfectly and the Mount has open holes for the speaker and camera. Only problem is that the suction disc is larger than oem ones so it has to be placed PERFECTLY center on my mounting pad or it doesn't stick. Not a big deal. Just takes a few tries and it's good to go. My only gripe with this phone is having the charge port and headphone jack on opposite ends. When in the mount and using the phone for music and navi, cords hang down both sides of my head unit. Makes using the climate control a little bit of a hassle. Lol
    sent from Galaxy Note 2
    01-07-2013 02:52 PM
  13. EnlightenedSoul's Avatar
    I use a tao tronics phone holder that suctions to the windshield. Purchased from Amazon. Definitely a no frills holder that gets the job done.
    01-07-2013 02:53 PM
  14. duenan's Avatar
    So where does one get a mount like the op has?
    I saw one on amazon but it was a cd mount, not the one the op has pictured.
    Which one is better anyway or is it just a matter of preference?
    01-07-2013 06:28 PM
  15. EnlightenedSoul's Avatar
    Most likely its a matter of preference, I like the suction cups similar to my tao tronics because I can remove it when I'm finished.
    01-08-2013 12:08 PM
  16. Hector709's Avatar
    I was thinking about getting this one. How do you like it?
    01-08-2013 05:21 PM
  17. JediJesus95's Avatar
    I also got that one due to this post and it works great as long as your display is below the cd player. If the cd player is above the display you can't see most of your display. It's a very sturdy mount that can be installed and taken down in less then 10 seconds.
    01-08-2013 09:41 PM
  1. Pictures of VZW Car Mount Install: Clunky but Functional
    By WhoMe in forum Thunderbolt Accessories
    Last Post: 04-03-2011, 06:05 PM
  2. Any site that ISN'T sold out on the mm station or car mount?
    By prmamidedos in forum Motorola Droid
    Last Post: 12-04-2009, 01:58 PM
  3. Phone sideways in car mount
    By SpeedVX in forum Motorola Droid
    Last Post: 12-02-2009, 02:38 PM
  4. My Homemade Droid Car Mount
    By thekC in forum Motorola Droid
    Last Post: 11-22-2009, 11:39 AM
  5. 20% of DROID car mount, hurry.
    By matrix2004 in forum Motorola Droid
    Last Post: 11-15-2009, 11:03 PM
