Results 1 to 14 of 14
    Default How do I get notifications to make noise, and not vibrate when set to "sound"?
    The whole notification end of this phone is more complicated than it needs to be...
    So far, if I put it on vibrate and I don't have "vibrate" selected in the apps and emails, it doesn't do anything.
    If I select vibrate in the apps and email and set it to "sound", it not only makes noise but also vibrates too.
    Is there a way to have it make noise and not vibrate when set to sound? And conversely have it only vibrate when set to vibrate?
    Here's my settings.
  2. #2
    MrSmith317's Avatar
    Mr Fix-It
    Posts
    ROM
    Stock Rooted
    Default Re: How do I get notifications to make noise, and not vibrate when set to "sound"?
    You can generically but per app, no. The sound/vibrate/mute profile will only effect the notification and ringer volume. However if you have gmail set to vibrate then it will vibrate no matter what.
    “Around here, however, we don't look backwards for very long.
    We keep moving forward, opening up new doors and doing new things,
    because we're curious...and curiosity keeps leading us down new paths.”
    -Walt Disney
    The issue I'm having is that if I leave gmail setting vibrate unchecked and I set the phone to vibrate, nothing happens.
    What am I doing wrong here? This seems like it should be pretty simple.
  4. #4
    gafly's Avatar
    Posts
    Global Posts
    828 Global Posts
    Quote Originally Posted by deputydog95 View Post
    If an app has its own notification settings (tone, sound, vibration, notification light) it will follow them. If an app does not have its own notification settings it will follow the system notification settings.
    Sent from my Galaxy Note II
    Galaxy Note II - Rooted - Black Status Bar w/WiFi Toggle
    So has anyone found a way to have the phone vibrate on a gmail notification when only set to vibrate? Versus it vibrating all the time whether set to sound or vibrate?
    Apparently this is an OS issue. I'm surprised there aren't more people on here complaining. I find this a huge PITA.
    Here's a link to some folks discussing it:
  7. #7
    After looking at your settings, you clearly have vibration turned on. If you don't want your device to vibrate, turn off the vibration. I have my vibration settings turned off, and guess what? My phone doesn't vibrate...
    Sent from my Transformer Pad TF700T using Tapatalk HD
  8. Thread Author  Thread Author    #8
    The problem is. It either vibrates all the time, or doesn't vibrate at all. I don't want it to vibrate when the sound is on. Just when set to vibrate. Even the ifail has a simple switch that allows you switch all audible notifications to vibrate.
    I don't understand why this phone can't do that..... Why would I want it to vibrate when the sound is on. So dumb.... This makes me miss my blackberry at times....
  9. #9
    Not to get too far off topic, but I'm having a problem getting my standard Email (not Gmail) to notify me with either a vibration or a sound. Neither one of them work. And I've got all my settings in the email and in Settings set to vibrate and ring for all notifications (just to see if I can figure out whats wrong). Nothing is working. The more I read the more it seems this is a Jelly Bean issue...
  10. #10
    Most custom ROMs have customizable toggle actions. The one I'm using does... I can toggle all notifications to sound only/vibrate only/sound + vibrate. One of the awesome things about Android... Infinite customizations. If you don't like something about your phone, or its operation, more than likely someone has already figured out a way for you to make it the way you want it. Rooting is the first step... Once your phone is rooted, you can do just about anything with it
    Sent from my SGS2 Skyrocket w/ Tapatalk 2
  11. #11
    Quote Originally Posted by ctgolf View Post
    I'm not having email issues at all w/ JB. But I'm not using Gmail or the native email app. I've deleted both, actually. AquaMail is awesome... Never gives me an ounce of trouble. And looks a lot better than Gmail, too LOL
  12. #12
    I let LightFlow control all my Notifications for me-->
  13. #13
    JerseyDubbin's Avatar
    Open Source For Life!
    Posts
    Global Posts
    206 Global Posts
    ROM
    Beans v7
    Weird,
    When i set mine to vibrate it vibrates with every type of alert.
  14. #14
    Quote Originally Posted by Lanhoj View Post
    Light Flow Lite works! Thanks! Made my morning
  1. How do I get NOTIFICATION on FOURSQUARE?
    By rossini in forum Verizon Droid Incredible
    Last Post: 08-16-2011, 10:42 PM
  2. How do I get Itues library onto Charge and play ?
    By rorkin in forum Verizon Droid Charge
    Last Post: 06-10-2011, 09:47 AM
  3. Native email client not pushing when set to push
    By manhattanmarg in forum HTC Flyer
    Last Post: 06-04-2011, 07:13 PM
  4. Replies: 11
    Last Post: 01-14-2011, 07:36 PM
  5. How do I get landscape Virtual keyboard to appear?
    By BerrySquasher in forum Motorola Droid
    Last Post: 11-14-2009, 04:55 PM
