1. Nibs's Avatar
    Hi all....I seem to be getting this message a few times a day and it's starting to bother me. I'll send a message and it will either "send" and come back as failed or it'll straight up say "No Network Connection". It has happened when I was connected to both 4G and 3G with strong signals. Not sure if I'm the only one. I'll try to get a screenshot next time it happens.
    Anyone else having this issue? I'm pretty new to Android so I'm not sure how to go about this...
    12-19-2012 11:32 AM
  2. Zs2art's Avatar
    My only suggestion would be to verify that your mobile data is turned on. I would assume however that if this was the issue you would be seeing more problems. Thats an odd one....
    12-19-2012 11:51 AM
  3. Nibs's Avatar
    Data is always on...it has happened with wifi both on and off so I don't think the connection is an issue.
    Sometimes I'll send a message and it fails and I try over and over and it keeps failing (even though I have a connection). It eventually sends but it takes a few retries.
    12-19-2012 12:03 PM
  4. Markster1's Avatar
    That's happened with me as well. Just turn mobile data off then toggle back on and fixed it for me.
    12-21-2012 06:57 AM
  5. Nibs's Avatar
    I finally got a screenshot of it. See on the top I clearly have a connection.
    Attached Thumbnails "No Network Connection" when texting-uploadfromtaptalk1357310214862.jpg
    01-04-2013 08:37 AM
  6. DroidXcon's Avatar
    Try settings>more settings>Mobile networks>Network mode>LTE/CDMA
    If this does not fix the problem, i imagine your sim card may be damaged.
    01-04-2013 05:12 PM
  7. Nibs's Avatar
    Alright thanks! Hopefully that works....it was set to global.
    01-04-2013 10:55 PM
  8. DroidXcon's Avatar
    Please update us , good luck
    01-04-2013 11:33 PM
  9. randalldavis's Avatar
    Mine is set to global and I have not had this problem.
    What is the difference in global and LTE/CDMA.?
    Which is the better setting and why?
    Thanks
    Randall
    01-05-2013 09:06 PM
  10. DroidXcon's Avatar
    Thanks
    Randall
    Global looks for wider range of frequencies ..lte/cdma looks for just those
    From my Galaxy Note 2 via Tapatalk
    01-05-2013 09:27 PM
  1. no network connection i dont have emei
    By Ulises Zavala in forum Android 4.0 Ice Cream Sandwich
    Last Post: 01-22-2013, 09:36 PM
  2. T-Mobile Nexus S 4.0.4 Sim Card/No Network connectivity error
    By illmaticnexus in forum T-Mobile Nexus S
    Last Post: 06-02-2012, 01:43 AM
  3. No network connection suddenly
    By ApacheXMD in forum LG Optimus S
    Last Post: 12-06-2010, 11:39 PM
  4. No network connection when USB connected
    By BradPa in forum AT&T Captivate
    Last Post: 09-30-2010, 10:13 AM
  5. No Network Connection. Lovely. Just lovely.
    By Night Train in forum HTC EVO 4G
    Last Post: 07-10-2010, 11:47 AM
