I have a Gateway P-FX6860 laptop running Windows 7 Ultimate using a CISCO(Linksys) Wireless N USB adapter. I updated the adapter with the current drivers/software. There is an option to connect using WiFi Direct but when I scan for devices nothing is found.
Here's what it looks like:
However when I turn on WiFi direct with the Note and scan, it sees the laptop, but when I try to connect, it gives a Failed to Connect error.
[/IMG]
Any ideas?
Any ideas?
