1. sillyrabbitt123's Avatar
    12-22-2012 09:08 PM
  2. cj100570's Avatar
    Yes.
    sillyrabbitt123 likes this.
    12-22-2012 09:24 PM
  3. sndplace's Avatar
    Yes.
    Hello have you tried it? Does anyone know for sure that the back of the Note2 for all carriers are a the same. Thanks
    12-24-2012 04:46 PM
  4. K_Daddy's Avatar
    As far as I understand it the NFC is in the Battery, not the cover.
    Sent by Accident
    12-24-2012 04:51 PM
  5. cj100570's Avatar
    They Are All The Same! http://phandroid.com/2012/11/30/got-...a-unique-look/
    12-24-2012 05:23 PM
  6. Nightscape's Avatar
    They're all the same. I bought a genuine flip cover online (not carrier specific) and a flip cover at the verizon store as well. They all fit the same.
    12-24-2012 05:23 PM
  7. leroybrute's Avatar
    Sent by Accident
    The NFC antenna is in the cover. However in every cover other than VZW's, wireless charging is included I believe.
    12-24-2012 06:10 PM
  8. sillyrabbitt123's Avatar
    What does that mean charging is not part of vzw?
    Thanks
    Sent from my SCH-I605 using Android Central Forums
    12-24-2012 09:23 PM
  9. maxburn's Avatar
    What does that mean WIRELESS charging is not part of vzw?
    I think he meant the bold part. Verizon does all sorts of stupid stuff to bastardize good phones and services.
    12-25-2012 07:56 AM
  10. cj100570's Avatar
    That is incorrect. Non of the covers come with the inductive coils for wireless charging. The Verizon version is however the only one missing the contact points that connect the cover to the phone body.
    leroybrute likes this.
    12-25-2012 02:13 PM
  11. leroybrute's Avatar
    As per my quote I wasn't positive. Thanks for the correction.
    12-25-2012 10:30 PM
  12. cj100570's Avatar
    Sorry if I came across rude. That wasn't my intent. But as I reread it it does come off kind of d-bag-ish.
    12-29-2012 02:10 PM
  13. leroybrute's Avatar
    No I didn't take it rude. I appreciate feedback. If anything I was just pointing out my comment so I didn't look stupid. LoL.
    12-30-2012 01:09 AM
  1. Will VZW replace my battery cover?
    By Droid3r in forum Verizon Droid Charge
    Last Post: 06-12-2012, 06:20 PM
  2. Can't get the battery cover back on!
    By MikeNY in forum Verizon Galaxy Nexus
    Last Post: 01-20-2012, 05:31 PM
  3. SEIDIO 3500 battery cover not fitting correctly?
    By m a x i m u s in forum HTC EVO 4G
    Last Post: 05-20-2011, 09:25 PM
  4. Will the Verizon extended battery /new back fit in Seidio Innocase?
    By greydarrah in forum Droid X Accessories
    Last Post: 09-29-2010, 08:43 PM
  5. ok, who will create a new battery cover with a kickstand?
    By zrxoa1 in forum Incredible Accessories
    Last Post: 09-25-2010, 12:20 PM
