1. Easton091's Avatar
    Anyone else having a issue not being able to control media volume? Everytime I go to YouTube, my media volume is greyed out. If I reboot the phone it seems to come back.
    Sent from my Galaxy Note 2 using Tapatalk 2
    12-25-2012 07:14 PM
  2. 4 Star General's Avatar
    Same issue here, I reboot as well
    Sent from my bad azz Vz Note2
    12-25-2012 08:06 PM
  3. Easton091's Avatar
    Hopefully there is a fix for it
    12-26-2012 06:21 AM
  4. eps's Avatar
    Is every VZW Note 2 experiencing this bug? I was planning to get this phone but this would be a deal killer.
    12-27-2012 08:18 PM
  5. 4 Star General's Avatar
    It's not worth being a deal killer.
    12-27-2012 09:01 PM
  6. dominick_7's Avatar
    Does it give you the option to slide your finger up and down on the sides of the screen or is that just while playing a video file?
    12-27-2012 09:05 PM
  7. DenverCZBob's Avatar
    No problems with mine. Going to Youtube with the browser or using the youtube app, hitting the volume on the side of the phone brings up an onscreen volume control that I can either continue using the control on side of phone, or use finger to grab the slider on screen and move...
    -bob
    12-27-2012 09:29 PM
  8. karsdroid's Avatar
    not a problem for me....i use the hard volume buttons on the phone itself when in a media app. i do find it resets to a low "safe" volume when disconnected from my car, headphones, etc and i end up having to set it higher each time.
    12-27-2012 11:19 PM
  9. Easton091's Avatar
    Randomly I go into YouTube and can't control volume. I hit rocker and then the settings symbol and the media volume is greyed out and can't control it.
    12-28-2012 08:00 PM
  10. sux2bu's Avatar
    Mine did it for the first and only time today. Reboot fixed it. I've had mine for almost a month.
    12-28-2012 11:37 PM
  1. Media uses over 80% of my battery when off
    By roadrunner_taz in forum Motorola Droid 3
    Last Post: 10-12-2012, 03:53 PM
  2. Part of screen off when useing mhl
    By mattatwar in forum Google / Samsung Galaxy Nexus
    Last Post: 04-19-2012, 05:58 PM
  3. Volume button difficulties when using a case?
    By hal1 in forum Verizon HTC Rezound
    Last Post: 12-25-2011, 07:36 PM
  4. I miss the volume control on the lock screen of my Droid!
    By jeff275 in forum T-Mobile HTC Amaze 4G
    Last Post: 12-22-2011, 03:20 PM
  5. Any way to use volume controls without first unlocking?
    By z06c in forum Verizon HTC Thunderbolt
    Last Post: 04-20-2011, 01:38 PM
