1. reb0957's Avatar
    Can you use the flash player with the stock browser or do you have to DL another browser?
    TIA!
    I can get the player to play, the sound is good but the vid is just a bunch of diagonal lines.
    12-26-2012 12:54 PM
  2. pool_shark's Avatar
    I never use the stock browser so I can't answer that, but Dolphin Browser beta has flash support.
    12-26-2012 01:11 PM
  3. DaRkL3AD3R's Avatar
    Hey reb0957, the problem you're having is an issue with our phones alone. We must wait for Verizon to give us or 4.1.2 update to resolve this issue. The international phones already got the fix and it did cure this problem.
    The issue is 240p/480p videos. There's something wrong with how our phone renders them and it causes wierd garbled images. 360p/720p/1080p all render perfectly fine and smooth. So for now if you can prefer these videos be in that format. Otherwise you'll be stuck with the graphics corruption.
    12-26-2012 01:45 PM
  4. reb0957's Avatar
    How do I change the format of the vid I am trying to view?
    12-26-2012 02:32 PM
  5. cj100570's Avatar
    TIA!
    Adobe ceased production of Flash for Android and thus the OS doesn't support it. Any issues using it have absolutely nothing to do with Verizon. It's a Jelly Bean thing. However, Adobe does make the Flash Player available for download from it's page. The following link should sort you out;
    Adobe Community: How do I manually install Flash Player on my Android device? There was also a post a while back from Droid dog that may be of interest to you also; Guide To Adobe Flash On Jelly Bean Devices | | DroidDog Android BlogDroidDog Android Blog
    12-29-2012 07:31 PM
  6. sillyrabbitt123's Avatar
    What version of dolphin. I cannot get it to work it says flash is disabled.
    Sent from my SCH-I605 using Android Central Forums
    12-29-2012 07:49 PM
  7. pool_shark's Avatar
    I have dolphin browser beta 1.3.0.
    Attached Thumbnails Flash Player Help Stock browser-screenshot_2012-12-29-21-00-43.png
    12-29-2012 08:00 PM
  8. DroidXcon's Avatar
    You need Dolphin beta
    From my Galaxy Note 2 via Tapatalk
    12-29-2012 08:01 PM
  9. richdroidx's Avatar
    Switched to dolphin beta and it still says its disabled
    12-30-2012 07:05 AM
  10. Phoneguy108's Avatar
    TIA!
    Did it work ok for you with the stock browser?
    01-07-2013 06:19 PM
  11. reb0957's Avatar
    I didn'tget it to work with the stock browser and never tried Dolphin
    01-07-2013 07:41 PM
  12. N2myN2's Avatar
    Here you go. Try this. Worked for me and others here.
    Rob
    Installing Flash Player in stock phone.
    01-07-2013 07:57 PM
  1. flash player help
    By vegeta_2123 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 06-15-2011, 05:33 PM
  2. Stock Browser issue, please help
    By Underworld54 in forum Verizon Droid Incredible
    Last Post: 03-14-2011, 10:06 PM
  3. Flashing back to stock Help
    By jflexe99 in forum AT&T Captivate Rooting, ROMs, and Hacks
    Last Post: 10-15-2010, 08:13 PM
  4. could someone help me with the stock browser please?
    By rem_kujawa in forum HTC EVO 4G
    Last Post: 07-03-2010, 10:43 AM
