Page 2 of 2 FirstFirst 12
Results 26 to 48 of 48
Like Tree1Likes
  1. #26
    NHBass39's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock rom/rooted
    Default Re: How many battery pulls a day?
    Quote Originally Posted by sudbury78 View Post
    pizza, any idea how to "undo the script"?
    Droidxconn thinks this is the cause of my problems. However since chomp crashes a lot, I am not using it and will see if this stabilizes. I ultimately want to go back to out of box
    Still not fixed yet? What way did you root? I did mine the Odin way and zero battery pulls here. Something got messed up on your phone. Droid or pool shark I'm sure can help you.
  2. #27
    Casey Cheung's Avatar
    Posts
    Global Posts
    1,792 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've never had to do a battery pull, and I've had my Note 2 since day 1. I've had to do a soft reset sometimes using the power button when the Google Play store didn't work right.
  3. Thread Author  Thread Author    #28
    sudbury78's Avatar
    Posts
    Global Posts
    674 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by NHBass39 View Post
    Bass shark is working on it. I rooted via the exploit one step route. I think it's the memory swap exploit I did that is corrupting stuff, I can't get a firm answer if doing factory reset will wipe everything including all root items. OR,if I simply unroot via super user then the two rooted exploits I did will just go away.
  4. #29
    NHBass39's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock rom/rooted
    Maybe he help you go the odin root after you get it back to stock? It is very easy to do. Yet I had help from Droidxcon. Let me know how it works out.
  5. #30
    mileaway's Avatar
    Posts
    Global Posts
    133 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    none so far
  6. #31
    treb1797's Avatar
    Posts
    Global Posts
    53 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Zero so far ( knock on wood ). One of the main reasons I got rid of my S3 was because I was having to do at least 2 battery pulls a day. Only issue I have w/ the Note 2, if you want to call it one, is the browser forces close more often than on any device I have had.
  7. #32
    the1m.polo's Avatar
    Posts
    Global Posts
    535 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    0000000
    Sent from my SCH-I605 using Android Central Forums
  8. #33
    D07
    D07 is offline
    D07's Avatar
    Posts
    Global Posts
    62 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No battery pulls for me. Used to do it on occasion with my tbolt.
  9. #34
    Bowman53's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Not once here
  10. #35
    darkcorsair's Avatar
    Posts
    Global Posts
    58 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have had to do restarts where ive tried to adjust the media volume from one game to another and the phone wouldnt let me. But no battery pulls yet
  11. #36
    4 Star General's Avatar
    Posts
    Global Posts
    478 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Zero
    Sent from my bad azz Vz Note2
  12. #37
    pizza5's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    After having read a little I'm not sure what the practical benefit is of rooting. There seems to be always the potential for gremlins. Sure you can remove some bloat but is that more an annoyance than a problem. Have had my N2 for almost a month and have never had to pull battery. In fact, with extended battery I go days before even needing to recharge. Today, for instance, I went 24 hours before I got to 80% left and this is with my smaller extended battery. One day I will test my bigger big battery and am shooting for several days if not almost a week. Admittedly I don't do movies, or streaming or stuff like that, and use conservation techniques such as no wall paper, auto light, whatever else I can do to minimize drain.
  13. Thread Author  Thread Author    #38
    sudbury78's Avatar
    Posts
    Global Posts
    674 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Do you have a link to that extended battery? How much bulk does it add?
  14. #39
    etbooker's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    None yet mabye you should go back to stock because of all off the devices out, the Note 2 shoupd not be suffering those problem on a stock ROM.
    Sent from my Galaxy Note 2 using Android Central Forums
  15. #40
    NHBass39's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock rom/rooted
    Default
    No problem here on the stock rom rooted. There are a ton of benefits from being rooted.
  16. #41
    NHBass39's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock rom/rooted
    Are you all set now? I got your message last night.
    Sent from my Samsung Galaxy Note 2
  17. Thread Author  Thread Author    #42
    sudbury78's Avatar
    Posts
    Global Posts
    674 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have been force close and battery close free for 48 hours now with a factory reset and yes have been unlocked thanks to droidxcon and his incredible patience and help. Guy rocks. So as of now I am unlocked stock rooted. Will probably try beans rom soon as we had trouble with clean rom last night with my phone and the unzipping process not working. I have my multi window apps so I'm quite happy as is.
  18. #43
    NHBass39's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock rom/rooted
    Great.
  19. #44
    pizza5's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes. None to double.
  20. Thread Author  Thread Author    #45
    sudbury78's Avatar
    Posts
    Global Posts
    674 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Would love the link....
    Sent from my SCH-I605 using Tapatalk 2
  21. #46
    NHBass39's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock rom/rooted
    Why would you need an extended battery on this phone? My battery life is unbelievable with the stock one.
  22. Thread Author  Thread Author    #47
    sudbury78's Avatar
    Posts
    Global Posts
    674 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Why not have an extended battery if it doesn't add bulk. It's a bonus
  23. #48
    NHBass39's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock rom/rooted
    True, but I'd rather use that money for other things.
    sudbury78 likes this.
  1. How many batteries charges do you use a day?
    By Scatabrain in forum Verizon Galaxy Nexus
    Last Post: 04-26-2012, 12:32 PM
  2. How many batteries are there for this phone?
    By Z Overlord in forum Verizon Galaxy Nexus
    Last Post: 03-28-2012, 09:18 PM
  3. Poll: How many battery do you plan to buy for your GN?
    By mozy in forum Verizon Galaxy Nexus
    Last Post: 12-23-2011, 12:19 AM
  4. Replies: 25
    Last Post: 06-24-2010, 02:34 AM
  5. Replies: 6
    Last Post: 06-22-2010, 08:31 PM
