DEAL OF THE DAY: Save 43% on the Seidio SURFACE Case (with kickstand) for HTC One!
Page 1 of 2 12 LastLast
Results 1 to 25 of 48
Like Tree1Likes
    Default How many battery pulls a day?
    I am curious if you guys/gals find yourself pulling the battery for one reason or another daily. I seem to get force closes or just tonight my gallery stopped working stating I dont have enough memory which is complete BS. I am rooted and maybe stock is really the best way to be, I dont know. My excitement for the phone has really lowered since I have been rooted. I cant recall any if at all battery pulls in the 3 weeks prior.
    Sent from my Unlocked Galaxy Note 2!
  2. #2
    nismo591's Avatar
    Posts
    ROM
    Stock
    Default
    I haven't had to do a battery pull since my tbolt. My note hasn't had any issues im running stock with nova launcher
    Thanked by:
  3. #3
    Default Re: How many battery pulls a day?
    The only time I've done a battery pull with this device is when I flashed the multi window tool on cleanrom which wasn't needed.
  4. #4
    ibcop's Avatar
    Posts
    Global Posts
    3,913 Global Posts
    ROM
    Stock
    A big fat zero.....
  5. #5
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    Rooting does nothing to your phone by itself. It is what you do with root that causes issues, like deleting the wrong stuff...
    If you are doing a battery pull a day there is something really messed up
    Sent from the nexus of the Android world, the SGS3.
    Shark your a expert like droidxcon. What do you think? Chomp SMS just failed again . I think I need it wipe completely and start over as the backup may have some things in it causing these crashes.
  7. #7
    Quote Originally Posted by sudbury78 View Post
    At this point I agree that a factory reset is in order.
    I switch between stock rooted, beans 3, and cleanrom regularly, and I have no FC's or battery pulls.
    Have you flashed a ROM and if so did you wipe caches and factory reset?
    Did you mistakenly restore system apps with titanium backup?
  8. Thread Author  Thread Author    #8
    Nope. Droid is going to walk me through unlocking and flashing beans rom. So I think I will save my contacts calendar and pics on to my pc and do a factory wipe. I'll stay stock for a few days and see if everything runs smooth.
  9. #9
    You can make sure your calendar is synced with Google and you can export your contacts to the SD card.
    That will put the file on the internal SD card which will get wiped with a factory reset so if you do that, move it to your external card.
    The external card shouldn't be affected.
  10. Thread Author  Thread Author    #10
    I think I am okay with wiping external card too. I have that exploit in place which tricks the internal into thinking its the SD. All I have on there is my music and pictures that are on itunes (music) and in picassa/facebook picture wise so im okay wiping that too.
  11. #11
    I have never had to do a battery pull on my gnote 2. Never had any issues whatsoever. So far it's been one of the only phones that I've had for over a month with no battery pulls.
    Sent from the Beast that is Galaxy Note 2
  12. Thread Author  Thread Author    #12
    Yea something is bad on my end. I am new to this and got agressive with the calendar widget and the exploit to make the phone think internal is my sd card. I wonder if I downloaded something that is corrupt. I will do a complete total factory wipe right now as If I am selling it to someone.
    Shark: Do you know the option I need to uncheck in root manager to avoid not being able to root again? I used the simple exploit version.
  13. #13
    I haven't had to do a battery pull yet though I do battery-pulls on my Android device(s) once a week just out of habit. When I use an iDevice I do weekly restarts for the same, preventative-mainteance reasons. Does this help my Note 2? Not sure, but I'm a creature of habit and not likely to change.
    Sent from my SCH-I605 using Tapatalk 2
  14. #14
    JRZLocal's Avatar
    Posts
    Global Posts
    434 Global Posts
    ROM
    STOCK
    no battery pulls yet and i've had it since launch. I too am rooted but i don't use any launcher.
  15. #15
    Unfortunately I am not familiar with the exploit method as that became available some time after I rooted.
    I can look around though.
  16. #16
    Johnly's Avatar
    Posts
    ROM
    AOSP, & stock.
    Quote Originally Posted by JRZLocal View Post
    This....glad I can if need be lol.
  17. Thread Author  Thread Author    #17
    pool, it was a video posted in the root thread.. I just bumped it for you. I am not sure how to "undo" it.
  18. #18
    I only do battery pulls to change the actual battery. I rotate between two to three batteries using an external charger. I don't remember the last time I actually plugged my phone in to charge.
  19. #19
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    It is a script so it should go away when you flash the new rom. I would make sure that everything you want to save is off of both the internal and external storage. Also you might want to check the xda thread on it pretty thoroughly to see what other mistakes people made
  20. Thread Author  Thread Author    #20
    can anyone confirm if I do settings-back up and reset-factory data reset, will my phone unroot and go back to the state i got it out of the box? I want to be at that stage, depserately.
  21. Thread Author  Thread Author    #21
    pizza, any idea how to "undo the script"?
    Droidxconn thinks this is the cause of my problems. However since chomp crashes a lot, I am not using it and will see if this stabilizes. I ultimately want to go back to out of box
  22. #22
    If you just want to unroot there is an option in supersu to do full unroot.
  23. #23
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    I would check the script thread and then make sure everything is backed up and just Odin the latest stock Image you have. I am not sure there is an undo other than that but will take a quick look
  24. #24
    a big fat zero battery pulls for me also.....love this phone.
  25. Thread Author  Thread Author    #25
    I killed chomp SMS for the 15th time since Tuesday and that us what seems to force close. I now wonder if whenever it goes bad some corrupt data stays in my phone. I have now downloaded go SMS and its running well. Will give it another 24 hours and see.
    Experts: does data from apps stay in your phone when uninstalled?
  1. How many batteries charges do you use a day?
    By Scatabrain in forum Verizon Galaxy Nexus
    Last Post: 04-26-2012, 11:32 AM
  2. How many batteries are there for this phone?
    By Z Overlord in forum Verizon Galaxy Nexus
    Last Post: 03-28-2012, 08:18 PM
  3. Poll: How many battery do you plan to buy for your GN?
    By mozy in forum Verizon Galaxy Nexus
    Last Post: 12-22-2011, 11:19 PM
  4. Replies: 25
    Last Post: 06-24-2010, 01:34 AM
  5. Replies: 6
    Last Post: 06-22-2010, 07:31 PM
