Page 4 of 4 FirstFirst 1234
Results 76 to 88 of 88
Like Tree3Likes
  1. #76
    kamran rimon's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: SD card error "SD card is blank or has unsupported file system.
    Quote Originally Posted by jerry d1 View Post
    This cardrecovery app did not work. I have the photos because I can see them on my phone but the scanned and saw nothing; however my phone cannot mount nor format the card. The card cannot be seen or formatted from the PC either. This is a phone problem because it is happening to numerous SD cards of all types and all sizes. What you are saying then is there is a fundamental flaw in all SD cards? Not likely; it's an Android problem. Verizon wanted me to factory reset my phone or buy another card. Pathetic.
  2. #77
    N2u4now's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Jared French View Post
    This "error" might not actually be what it states itself to be (although it could be just that).
    I have received this error days after attempting to send a large photo via text message.
    I know that is what caused the error. In this case, it is actually not a bad SD card, and doesn't need to be reformatted, but the error will remain as long as the picture continues to try to send. It's in limbo, and there is no android error message for "you're an ***** stop trying to send enormous photos via text".
  3. #78
    yuytyuyt's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I ended up with the same blank sd problem. I took the sd card out then blew the dust off. After I tried, all of my info was still on it even though I hit the format button several times. When the problem started I reset the phone while an app was accessing the sd card to load a file. Maybe it had something to do with that? Idk, hope this helps.
  4. #79
    jamesdgreer79's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Talking Solved "SD card is blank or has unsupported file system"
    Hi jdraper2015,
    Solved SD Card Blank
    I was facing a similar problem in my samsung s3. I was using my phone on a trip to click photos and then suddenly this message started popping up. I was scarred that I would loose all my photos of not only this trip but also my past trips since I had never backed up my data. But l feel I was lucky to find an excellent step-by-step video tutorial which not only recovered my files but also fixed my SD Card.
    Here these are the steps that worked for me
    1> Inserted the sd card on a pc using an sd card reader
    2> Used photorec utility to recover my pictures
    3> Used testdisk utility to fix my corrupt sd card
    4> Backuped SD Card in PC
    4> Formated sd card in PC
    5> Repaired SD card using chkdsk
    6> Formated sd card again in phone
    7> Copied the backed up folders into my sd card
    The step-by-step video tutorial l found was over here: https://www.howisolve.com/blank-sd-c...covered-fixed/
    The Download link for the utilities are :TestDisk Download - CGSecurity
  5. #80
    scottbiggs32's Avatar
    Posts
    Global Posts
    34 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Already tried all fixes like changing drive letter, chkdsk, running a formatter tool, unlocking swtch?
  6. #81
    jgjackjg's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    what happens, or how can i fix it if i did.
  7. #82
    Cheryl Diggs's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    SD. Card. Is. Blank. And. Reads. Unsupported. File. In. My. lg. Smrt. Ph. Want. To. Add. Songs. To. It. From. YouTube. Playlist. And. Insert. It. In. Bluetooth
  8. #83
    Arakelthedargon's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Format the card in to FAT32 with mini tool partition wizard. Do not remove the file system and than create a new file system in order to save your data! Format everything! After the formatting is done insert your SD card in to the phone and be patient because it may take a few minutes for the phone to check errors and accept the card.
    Tested on Samsung Galaxy Fame S6810, Android Version 4.1.2( Not updated with the Samsung service because it is rooted), Rooted with Iroot( or KingRoot as also known). I hope this helps please vote if it helps!
    In order to check if your card is defective please use h2testw. If you do not want to wait you can only write and verify 10GB of data but that may not be accurate. It takes a lot of time( Hours may 2 days depending on the data amount) but it is worth it!
  9. #84
    Loveliveandlearn1985's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The card is new and blank, but when put in my phone and every other says "blank sd or has unsupported file systems"... my phone storage is maxed out, and I need this card to stop tripping please!
  10. #85
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Read the previous post!
  11. #86
    sahil talwar's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I tried a lot but I got a way to backup my sd card ( make sure you are rooted). but for that to work you have to go into the recovery mode {i did it with team win recovery(for those who dont know team win recovery, its just a different kind of clockwork mod recovery) } of the phone .
    what I did was i inserted my sd card into the phone and entered into the recovery mode and then i attached my phone to the computer via usb cable (i am still in the recovery mode) . now from there go to "mount" tick the sd card box button from all the boxes available , next just press the button named (disable /enable MTP). and when you click that you will see your device displayed in the my computer section and inside that you see your external sd card files which can now be easily retained . i hope it helps.
    if you have any problem just comment.
    and if doesnt seem somewhat clear to you i can still make a video for the same .reply if you want
  12. #87
    firthousft's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by bastardNis View Post
    My problem is that sd card is blank or not suported,and when i inserted it in desktop it is not recognized at all... anyone help?.thanks
  13. #88
    firthousft's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    SD card error "SD card is blank or has unsupported file system my phone is Samsung j2
  1. Sd card blank or has unsupported file system
    By Cjclassen88 in forum General Help and How To
    Last Post: 10-14-2015, 08:33 AM
  2. HELP! "SD card is blank or has unsupported filesystem"?!?!
    By jacquimartin1225 in forum Introductions
    Last Post: 04-09-2013, 06:08 AM
  3. Why does it say the SD card is blank?
    By nicoles0927 in forum Verizon Droid Incredible 2
    Last Post: 06-13-2011, 09:15 AM
  4. SD Card Error Message
    By MasonMI in forum HTC Droid Eris
    Last Post: 12-29-2010, 02:40 PM
  5. sd card error
    By countrychic84 in forum HTC Hero
    Last Post: 06-10-2010, 04:25 AM
