- 01-01-2013, 11:31 PM
Thread Author #1
Nova Launcher Help
I really want to like this launcher but it has one annoyance I need help with! Can anyone tell me how you get rid of the solid line in the upper left corner by the clock? I'm sure it's supposed to serve some purpose as in aiding with noficiations but I find it very distracting and annoying. Anyone know where in the settings this line can be hidden if it can? Thanks!
- 01-02-2013, 06:37 AM #2
- 01-02-2013, 06:45 AM #3
- 01-02-2013, 06:55 AM #4
Re: Nova Launcher Help
My preference of 3rd party launchers has to do with the added features.
3rd party launchers give the ability to rotate the home screen, launch many apps without having icons all over the screen or going into the app drawer, hide the notification bar and dock icons.
For instance, with Nova, you have the 5 dock icons at the bottom, just like TW, but with Nova, each of the 5 icons can launch 2 apps. Nova also has swipe gestures allowing you to launch additional apps.
I have 3 rows of dock icons using nova, (I think you can have up to 5 or more rows). Each one can launch 2 apps. It also has a swipe up, down, 2 finger swipe up, down, and rotate right and left.
With my current setup, I can launch 36 apps from my without ever going into the app drawer and without having my screens cluttered with icons. - 01-02-2013, 09:33 AM #5
No line here either, I'm not sure what you're seeing.
I really like Nova Launcher Prime as well. The gestures are awesome and completely customizable. Infinite scrolling on the home screen, dock, and apps if you want it. Lots of options to customize look, feel, and performance. You can change the scroll effect you see when swiping between home screens and the speed of the effects/animations.
I can launch almost anything I need right from my main home screen. I keep a blank spot so I can double-tap to open Voice Search, and I like having a mostly blank desktop to stare at my live wall paper.
A lot of the 3rd party launchers have features like this, I've had good luck with Nova Prime and WidgetLocker. - 01-02-2013, 10:23 AM
Thread Author #6
- 01-02-2013, 11:10 AM #7
- 01-02-2013, 11:34 AM
Thread Author #8
- 01-02-2013, 11:41 AM #9
- 01-02-2013, 02:42 PM #10
I have heard that auto updating widgets left running in Touchwiz can have an effect on battery life, but I don't know this for sure. If you are happy with your third party launcher it is probably best to go into Touchwiz and delete any widgets from your home screens.
Samsung Galaxy S4 - AT&T
Samsung Galaxy Note 10.1 LTE - VZ
Galaxy Note 8
Apple iPad3 - 64GB LTE - 01-02-2013, 03:25 PM #11
Nova Launcher Widget Help
By kgjeter in forum Droid RAZR MAXXReplies: 22Last Post: 12-06-2012, 08:56 AM -
Nova Launcher help
By md308 in forum Verizon Galaxy NexusReplies: 9Last Post: 02-11-2012, 09:38 PM -
Go launcher help please
By pank in forum Motorola Droid XReplies: 2Last Post: 08-26-2011, 10:50 AM -
GO Launcher Help
By pwostran in forum Verizon Fascinate Rooting, ROMs, and HacksReplies: 3Last Post: 03-08-2011, 08:58 AM -
Home launcher help
By minnis12 in forum LG Optimus SReplies: 7Last Post: 02-01-2011, 12:26 AM
Reply
