Samsung Galaxy Note 2 with Verizon data only?
I am thinking of getting an unlocked Samsung Galaxy Note 2 and buying a prepaid plan from Verizon. My intention is to use data only (99c/day) to cover all my phone needs (i.e. making/receiving calls and SMS through apps like Talkatone, Viber, Skype). Would that work? Is there a problem with this setup?
Thanks in advance,
Nikos
Re: Samsung Galaxy Note 2 with Verizon data only?
Thanks in advance,
Nikos
Unless it's a Verizon note 2 it won't work
From my Galaxy Note 2 via Tapatalk
If that works then for $30 you can get unlimited data usage plus voice/text via apps without using voice minutes. Is that too good to be true? Has anyone tried it?
Also I think verizon is mainly CDMA based network but I've read that they started making phones with both CDMA and GSM capabilities for international usage. Does verizon make Note 2 with both CDMA and GSM capabilities?
Yeah Verizon note 2 will work on other networks. Like I have used mine on At&t but you can't use At&t note 2 on Verizon
As far as I know, they won't let you get just a data plan on a phone. I think you minimally have to buy the cheapest plan for voice which is $39.99. You could call and ask, but that's what they've told me before. They told me I could always get just a data plan of course on tablets, but not phones. Also last time I was trying to see if I could get a prepaid plan on my droid charge, and they said the prepaid plan is only for specific phones that are listed on their website, but who knows, they could have been wrong.
Will the phone work outside the US on GSM 900,1800 and 1900 frequency bands (i.e. in Europe)?
Yes it will but VW hasn't given us the ability to add APN for data so only text and voice over seas for now.
You can root and add them.
Which will also void my warranty!
If you return it rooted. If you unroot its not an issue
