Page 4 of 4 FirstFirst 1234
Results 76 to 82 of 82
Like Tree2Likes
  1. #76
    Roger Andrew's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Samsung Galaxy Note 2 USB PC Connection problem
    Quote Originally Posted by Rakesh Kanojia View Post
    my Samsung note 2 is not connecting with my PC
  2. #77
    Vlad Milenski's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the tip - apparently it was my USB cable too.
  3. #78
    GuccizBud's Avatar
    Posts
    Global Posts
    27 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Exclamation Re: Samsung Galaxy Note 2 USB PC Connection problem
    >> Nothing happens when I press *#7284#. I then hit
    >> dial and Verizon gives me a messages asking
    >> what the hell do I think I'm doing.
    > Well, that is Jack's first and only post on this forum.
    > I'm guessing it's spam. I would never do anything
    > that someone suggests in their first post on a forum.
    Long after the fact, but for future visitors...
    It wasn't spam. The code given works. The reason nothing happened when the guy tried it on his device is because he wasn't using the stock dialer. If you downloaded any other dialer obviously none of the Samsung dial codes will work.
  4. #79
    SameProblem's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for that answer. Working from that I realised the USB socket on my phone had so much dust and pocket lint in it that the cable couldn't make a connection.
  5. #80
    kim524's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have connectivity problems with my Samsung Galaxy Note 2 and I have tried SkipSoft. I think it looks like a great and helpful program. I am having a simple and aggravating problem. I have set my driver options to not let Windows install its own. That was the way my computer was set already. I have checked and double checked the setting, rebooted my computer. When I connect my phone, Windows still installs its own driver. I can see it in the device manager. I have uninstalled the Windows driver twice, rebooted each time. To no avail. I plug my phone in, Windows triumphantly installs its own driver, which doesn't work right.
    I run Windows 7. I have successfully installed the SkipSoft software, all it needs is a chance to get to my phone before Windows does.
  6. #81
    OlaRufai's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Lightbulb Re: Samsung Galaxy Note 2 USB PC Connection problem
    It worked for me! Thank you .
    Quote Originally Posted by Jack Mai View Post
    Hi guys and girls.
    Hope this will help yougall.
    I had this problem too and this is how I fix it.
    1) get in to your note phone key pad press *#7284# (no this is not a joke)
    When you press the last star (#) This will bring up an option that will ask you usb (modem or PDA)
    2) change it to PDA.
    3) at the bottem it says qualcomm usb. Click on it.
    4) in side the click on MTP + ADB.
    5) Then save and reset.
    6) wait........
    7) wait......
    8) when its back on. Thank god it did not blow up
    9) plug micro to the note 2 and the the other end to your PC Or mac or what ever u have
    10) let your computer down load and install drivers..
    11) wait.......
    12) wait.....
    13) wait some more...
    14) when installing is all done. Unplug then replug phone.
    15) there should be a USB symbol on your phone click on it. It should ask if you wsnd to use mtp or ptp.
    Click MTP. Note some my have to click PTP for it to work.
    16) check your computer for your open. On how to open your files.
    17) Do dance of joy.
    Note if this dont work please to not do #17 and stop reading.
  7. #82
    OlaRufai's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It Worked for me! Thank you.
  1. Samsung Galaxy Note 30-Pin extension cable? Dock Connector to Micro USB?
    By htc evo 4g in forum Samsung Galaxy Note 10.1
    Last Post: 07-22-2013, 11:04 PM
  2. Samsung Galaxy Note 2 could not connect to pc
    By Melvin Soo in forum AT&T Galaxy Note 2
    Last Post: 05-20-2013, 06:33 PM
  3. Replies: 0
    Last Post: 12-16-2012, 03:35 AM
  4. Problems connecting Samsung Galaxy Nexus to PC. Please help?!
    By sizzlinninja in forum Google / Samsung Galaxy Nexus
    Last Post: 11-24-2012, 01:12 PM
  5. Samsung galaxy note pictures to be set as PC background
    By dg83xx in forum Samsung Galaxy Note
    Last Post: 07-19-2012, 02:43 AM
