Page 6 of 8 FirstFirst ... 345678 LastLast
Results 126 to 150 of 180
Like Tree29Likes
  1. #126
    Droid_Evo_8's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Default Re: 4000mah Ebay Battery review
    Quote Originally Posted by jbomb View Post
    4000 review.
    Seems similar to stock on first cycle.
    Sent from my Note Dos.
    You happened to know what's your screen time? Cause I'm getting almost 6 hrs on mine on average on the stock battery.
    Attached Thumbnails Attached Thumbnails 4000mah Ebay Battery review-battery.png   4000mah Ebay Battery review-screen.png
  2. Thread Author  Thread Author    #127
    YukeYukeTroublemaker's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    4000 review.
    http://img.tapatalk.com/d/13/02/02/e8ygu3ys.jpg
    I was disappointed on my first and second cycle as well.. however it just got better and better with each charge...
  3. #128
    Eclipse2K's Avatar
    Posts
    Global Posts
    5,970 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    How much better is this really? I can go 6 hours of screen time and 18 hours with about 30% battery remaining on a stock battery.
    **Estimates
    Sent from my Samsung Galaxy Note II using Tapatalk 2.
  4. Thread Author  Thread Author    #129
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Eclipse2K View Post
    **Estimates
    See post#115. I got over 38 hours with over 6 hours screen time with 3% left...
  5. #130
    7711's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    another option to consider, there is a 6200 ma battery branded as hyperion that comes with its own back plate and a case is available. I ordered them from amazon and will probably see them Tuesday. I hope that battery will let me run gps and blue tooth for a long day and have some hours of screen time and talk time. My plan is to save that battery for trips and outings.
    mrxblue likes this.
  6. #131
    dt81's Avatar
    Posts
    Global Posts
    1,208 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by 7711 View Post
    take pics of the back on it when it comes in, I'd like to see how much thickness the battery cover will add to it.
  7. #132
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    OR, get the 4000mah battery that's mentioned in this thread plus this. You'll now have a total of 8000mah of battery life on your Galaxy Note 2.
  8. #133
    dt81's Avatar
    Posts
    Global Posts
    1,208 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    people don't like to have to switch out batteries all the time though.
  9. #134
    Synycalwon's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by DT81 View Post
    That's true, although the Note 2 gets great battery life (even on the stock 3100mAh battery), so it minimizes how often you'd need to swap em out. Regardless, IMO it's an awesome option to have though versus phone's with a sealed battery.
  10. #135
    Ed270's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just got mine. I will pull the film from the contacts and pop it in the charger and see how it does
    Sent from my SCH-I605 using Android Central Forums
    mrxblue likes this.
  11. #136
    mrxblue's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Ed270 View Post
    Let us know how your testing goes, inquiring minds wants to know.
    Sent from Samsung galaxy note 2 (Verizon), titanium color
  12. #137
    Ed270's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It may take a few charging cycles but I will post back with my results and of course screen shots of " on screen time"
  13. #138
    Ed270's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This is my result with the stock battery
    And this with the 4000 Mah battery after day 1
    Will post again Tomorrow with day 2
  14. #139
    mrxblue's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for your initial impressions. Look forward to how day2 goes.
    From your screenshots, it actually looks like the 4000mah is losing juice at a faster rate. Is that what you're seeing too ?
  15. #140
    dt81's Avatar
    Posts
    Global Posts
    1,208 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    the first charge did on mine too. The second and third day you will see a huge difference
  16. #141
    Ed270's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well it's day 2 and my battery is at a higher level than yesterday but a little less screen time today. I forgot to mention that yesterday I put it through some heavy use as a was installing different boot animations and kept turning my phone on and off about a dozen times I am also on 4G for about 90% of the up time as I have no wi-fi
    at work . I have also been using navigation with full time gps for my work commute and been using battery saving mode with cpu management off
ID:	59441Click image for larger version.
    mrxblue likes this.
  17. #142
    mrxblue's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The percentage remaining is covered but i think it says ~28%. But the day is half over.
    aren't you averaging around 20 hours with maybe 10-15% remaining battery life? When you were on stock battery ?
  18. #143
    Ed270's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It was 28% I don't believe my stock battery screen said 20 hours as I charge my phone every night there was a period today that I turned my phone off for a few hours
  19. #144
    Ed270's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well it's day 3 and I am not seeing much difference maybe even a little worse performance today. Less screen time and less usage on my part as it was a busy day at work. But for $12 you get what you pay for. Btw I am at 16% and the phone went off charge at 5am no bump charges or shut off time
    Sent from my SCH-I605 using Xparent BlueTapatalk 2
    mrxblue likes this.
  20. #145
    dt81's Avatar
    Posts
    Global Posts
    1,208 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I can go a full 24 hours on my 4000mah. I really do love it
  21. #146
    mrxblue's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    http://img.tapatalk.com/d/13/02/08/saga5yne.jpg
    http://img.tapatalk.com/d/13/02/08/ubesesa6.jpg
    http://img.tapatalk.com/d/13/02/08/sa2a4ahy.jpg
    16 hrs uptime with with 18% left is pretty good.
    I'd be interested in seeing if you went back to the stock battery if you see equal or better battery, give and take how busy the day is
  22. #147
    Ed270's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It is hard to get two work days where I can try to match usage. This battery is not a waste of money. But I was not getting bad service out of the stock either. I guess I expected this battery to make me go WOW and I am not feeling it. I will put the stock one in tomorrow and see how it goes.
    mrxblue likes this.
  23. Thread Author  Thread Author    #148
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ed you sound like more of a heavy power user by the way you are running this battery down. For you i think you need one of those 6000+mah batteries with the different rear battery door!!!
  24. #149
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Quote Originally Posted by YukeYukeTroublemaker View Post
    Or, add one of these to keep the slim profile of the note 2. You'll now have 8000mah instead. Hehe
  25. #150
    Roustermiller's Avatar
    Posts
    Global Posts
    446 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    My battery should be here today waiting on the mail man now. I hope they get here before the storm hits.
    Sent From My Galaxy Note 2 Using Tapatalk 2
  1. Ebay/Amazon Replacement Battery Reviews?
    By Dave4321 in forum Samsung Galaxy S3
    Last Post: 07-18-2012, 05:47 PM
  2. Chinese Ebay batteries...Huge thumbs up
    By CEaton in forum EVO Accessories
    Last Post: 11-12-2010, 07:31 PM
  3. 3000 mah Chinese battery review
    By EVOLICIOUS in forum HTC EVO 4G
    Last Post: 08-04-2010, 11:36 PM
  4. Replies: 1
    Last Post: 07-19-2010, 12:34 PM
  5. 10 dollar ebay battery review...
    By youngzayiles in forum EVO Accessories
    Last Post: 07-12-2010, 09:51 PM
