06-27-2014 03:38 PM
180 ... 5678
tools
  1. Tinmania's Avatar
    Anyway to get one of these from amazon and not need all that shipping time?
    Mike
    Sent from my SAMSUNG-SGH-I317 using Android Central Forums
    02-08-2013 12:46 PM
  2. Roustermiller's Avatar
    It's here just in time
    Sent From My Galaxy Note 2 Using Tapatalk 2
    Attached Thumbnails 4000mah Ebay Battery review-uploadfromtaptalk1360350369598.jpg
    mrxblue likes this.
    02-08-2013 01:06 PM
  3. Ed270's Avatar
    Well the 4000mah does a little better than stock as I had the stock battery in today.And I am down to 12% and its not time to go on the charge plus I cheated a little today and turned 4G off while I had to go out int the field for a total of 4 hours so I feel a little better about the larger battery
    Sent from my SCH-I605 using Xparent BlueTapatalk 2
    mrxblue likes this.
    02-08-2013 07:32 PM
  4. Eclipse2K's Avatar
    What's your call time? Was the screen on for internet and texting?
    Sent from my Samsung Galaxy Note II using Tapatalk 2.
    02-08-2013 07:34 PM
  5. mrxblue's Avatar
    http://img.tapatalk.com/d/13/02/09/usa9y4eb.jpg
    http://img.tapatalk.com/d/13/02/09/edy7a2as.jpg
    Thanks for testing and posting your results
    Swyped from Samsung galaxy note 2 (Verizon), titanium color
    02-08-2013 08:11 PM
  6. Ed270's Avatar
    The screen was on for more internet than texting mostly looking at forums
    02-08-2013 08:11 PM
  7. Eclipse2K's Avatar
    Okay, so the stock battery performed well for most of us.
    02-08-2013 08:18 PM
  8. dt81's Avatar
    hey, if this storm knocks out power for me... I have 1 3100mah, 2 3500mah and 1 4000mah battery to keep me happy!!! Woohoo
    Eclipse2K and msndrstood like this.
    02-09-2013 12:06 AM
  9. fwhomeboy's Avatar
    OK, after the third cycle, I got 22 hours out of the battery. This time, I was using my phone for my mobile hotspot for my laptop all day trying to drain the battery down. This will be the first day on a full charge after my third cycle. This will be the day to see if the 4000 mah battery is worth all that money I paid for it. $11.99 US.
    Update: After using the battery for two weeks, yesterday I noticed that the battery went all the way down to 12% on normal usage. But, I'm not gonna say the battery is starting to fail. I had almost no signal most of the day so it might just be working overtime trying to obtain a signal. I just took it off charge so it's at 100% now and I'll post back later tonight on the latest update. BTW, I put in my OEM battery to charge it up for the first time in two weeks and it was still at 100%. Thats good to know. Good luck with yours. I can say it has been awesome so far.
    mrxblue likes this.
    02-11-2013 10:31 AM
  10. dpham00's Avatar
    I have had bad luck with after market batteries in the past, most perform okay when I first got it, but after a while, performance decreased, at a rate way faster than stock batteries.
    That, and cell phone batteries have exploded before. Yes, chance is very slim, but, imo, Samsung batteries are less likely to explode. Of course, a note 2 battery did explode, so anything is possible. It is easier to track down Samsung than some ebay vendor selling stuff from overseas.
    Sent from my Verizon Galaxy Note II
    universeand likes this.
    02-11-2013 10:46 AM
  11. ReuvenNY's Avatar
    02-11-2013 10:50 AM
  12. fwhomeboy's Avatar
    That was a Note 1 battery that exploded, not a Note 2.
    dpham00 likes this.
    02-11-2013 11:49 AM
  13. dpham00's Avatar
    Thanks for the correction.
    02-11-2013 11:56 AM
  14. mrxblue's Avatar
    Whew !
    02-11-2013 12:24 PM
  15. dt81's Avatar
    I mean no disrespect but u purchased a 3200mah battery and stock is 3100mah so you wont see much of a difference.
    02-11-2013 04:27 PM
  16. ReuvenNY's Avatar
    I was not looking for difference- I was looking for the same, and I got it. Many times you buy an after market battery that's worthless, but not the one I bought.
    02-11-2013 06:24 PM
  17. dt81's Avatar
    oh oh. I'm sorry.
    02-11-2013 08:05 PM
  18. fwhomeboy's Avatar
    OK folks heres the deal. The battery is still fine. I work on Aircraft and I am inside a Hangar for 8 hours a day and also inside the aircraft for most of that time. While at work I have about two bars of signal and that is a 3g signal if the hangar doors are closed. So, with that said, I still think this battery is good to go. The poor performance I had was in fact because the phone was digging deep to maintain a signal and dragged the battery down in the process. When the doors are open, I get a very good 4G signal and the battery doesn't suffer from it. All in all, the battery is worth every bit of the 12 bucks I spent. Again, good luck with yours.
    mrxblue likes this.
    02-13-2013 04:27 AM
  19. dt81's Avatar
    what airline? I also work for us airways
    02-13-2013 07:59 AM
  20. fwhomeboy's Avatar
    Not an Airline. A MRO in Greensboro, NC. TIMCO.
    02-13-2013 08:58 AM
  21. YukeYukeTroublemaker's Avatar
    I noticed this as well when I was in training in a basement with a huge concrete base... phone barely held 1 bar down there and battery drained quick... i think my battery would have died if the oem was still in there...
    02-13-2013 12:28 PM
  22. whostens's Avatar
    Been about 6 months since this thread has been given any love. Any long term updates from the 4000mah users ? Thanks in advance
    08-04-2013 12:14 PM
  23. Ed270's Avatar
    Mine bit the dust after about 2 months use at least it was only $12
    08-04-2013 12:24 PM
  24. pizza5's Avatar
    New here but have been a Note 2er since Dec. Have tried numerous extended batteries for this puppy and have been uniformly pleased. I divide them into those that fit within the original case and those that don't. I have used the 6200 and a 6500 mah battery and admittedly with light use I have gone up to 7 days before recharging. I have also seen a 9300 monster from somebody named "Zero Lemon" that must last to the day before infinity. Of course with these big boys you pay a price in size and heft but they are not that expensive with the exception of the 9300 which goes for about $40-$45 with a custom case. Have used a "Gold " 4200 and am currently testing a 4300 that fits within the original case. So far it looks promising. Oh, did I mention that the latter was less than $6. delivered. Am not a shil so you'll have to find it yourself beyond d-bay. BL, just because it is cheap and from our friends in China does not necessarily mean its a ticking bomb. Use your independent judgment as you would with wine. Few people can tell a $20 wine from a $100 wine. Don't be mindless and assume price is the only way to judge something.
    08-04-2013 08:35 PM
  25. YukeYukeTroublemaker's Avatar
    Mine is chugging along quite well... just to test I swapped in my old battery and best I managed was 18-19 hours under the same type usage I am using this battery... best under 20 buck battery I ever used!
    Attached Thumbnails 4000mah Ebay Battery review-2013-08-15-18-12-34.png   4000mah Ebay Battery review-2013-08-15-18-12-45.png
    08-15-2013 08:17 PM
180 ... 5678
  1. Ebay/Amazon Replacement Battery Reviews?
    By Dave4321 in forum Samsung Galaxy S3
    Last Post: 07-18-2012, 04:47 PM
  2. Chinese Ebay batteries...Huge thumbs up
    By CEaton in forum EVO Accessories
    Last Post: 11-12-2010, 06:31 PM
  3. 3000 mah Chinese battery review
    By EVOLICIOUS in forum HTC EVO 4G
    Last Post: 08-04-2010, 10:36 PM
  4. Replies: 1
    Last Post: 07-19-2010, 11:34 AM
  5. 10 dollar ebay battery review...
    By youngzayiles in forum EVO Accessories
    Last Post: 07-12-2010, 08:51 PM
