Anybody else have a problem when they do voice search for navigation for example when you say to the phone navigate to Starbucks and the results are awful for one Starbucks doesn't even come up. And it brings up unrelated suggestions. But if I type in what I'm looking for that it brings it up. It's driving me nuts. Thanks for any insight.
Sent from my SCH-I605 using Android Central Forums
Have not experienced this problem because I rarely do voice searches like that but I will do some testing tonight to see if I can replicate the same issues your are having.
Im going to add to that question and ask whats the diff between standalone GPS, VZW location, and google location. Also which one should I be using?
Standalone GPS - Needed for Navigation and Turn by Turn directions. This usually can be left off unless you plan to use your phone as a GPS.
Google Location Services - Uses your phones WiFi/Data service to get your location to push to applications like Google Now, Weather Apps, Widgets etc in order to provide you with information based on your currentl locations. This is needed in order to weather updates on a Widget that wants to use your location instead of place you manually put it. You can leave this on if you want these features.
VZW Location Services - Never used it... my guess is same as Google Location Serivices but may be needed if you use VZWNavigator. My recommendation, turn this off and leave it off.
