Swipe right to call - Left to text not working
I saw it work once, but now it does nothing. I have done several factory resets to try to find the guilty APP or setting. I even reset without adding my gmail account to have a clean install. I am sure it is something simple but I have yet to tease it out.
I am talking about the feature when on a contact, you swipe right on the number to call the contact or swipe left to send a text to that number. It shows a tip the first time you go into contacts.
Thanks for any help.
jjw
ND
Re: Swipe right to call - Left to text not working
jjw
ND
You mean this right [Only registered and activated users can see links. Click Here To Register...]
From my Galaxy Note 2 via Tapatalk
Just gave it a try on my phone and it worked fine, brought me right to my text messages. You are sure that the contact your a trying to swipe to message has a valid mobile number?
Quote:
You mean this right
I see what you meant about being able to record your screen. I guess this really can be useful for pointing out certain features or how to access a given screen.
OP: Are you running a ROM or fully stock?
It is fully stock. I run Nova launcher, but like I said after 5 factory resets and setting it up with less to the point of being totally factory (no apps, no settings changed) it just could not locate the faulty app. The only thing I did every time was install Exchange as this adds my contacts. I had exchange loaded the time it worked or I would not have had a contact to call.
jjw
jjw
When you Swype it does it turn colors at all?
No colors or anything to give you a hint the option exists.
jjw
Just tried it on my N2 & it works fine.
