Results 1 to 5 of 5
    Default Multi view not opening correctly
    When I try to open multi view, I don't get the split screen, just one large screen for whatever icon I choose. Is this a setting I changed somehow?
  2. #2
    Default Re: Multi view not opening correctly
    Have you tried adding the second app? Just drag it to the top or bottom half of the screen.
    When I drag it over - it opens in the entire window instead of the multi-view/split screen. So if Im in my mail and try to grab S Note for example, S Note is all I see. Ive tried dragging to the top, bottom, etc
  4. #4
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Carrier
    Stock for now
    Quote Originally Posted by nejones64 View Post
    Have you tried toggling multi window from settings>display
    Also try shutting off settings> developers options
    From my Galaxy Note 2 via Tapatalk
    I turned off Power Savings and Multi View and then just turned on Multi View and it worked...seems odd to me
  1. android central not opening correctly
    By md17 in forum Verizon Droid Incredible
    Last Post: 11-11-2010, 11:06 PM
  2. Is the UserCP not working correctly?
    By sniffs in forum Site Feedback & Help
    Last Post: 01-29-2010, 11:28 AM
  3. Is the UserCP not working correctly?
    By sniffs in forum The Android Central Lounge
    Last Post: 01-28-2010, 01:40 PM
  4. google maps not getting correct current location
    By craigpicc in forum Samsung Moment
    Last Post: 11-16-2009, 05:36 AM
  5. Issue Apps not opening when clicked upon?
    By blackops#IM in forum Motorola Droid
    Last Post: 11-08-2009, 04:00 PM
